7
Enable 5G for Android 11 on OnePlus 8 series and OnePlus 7 5G
  1. NHN
    Eclair Jan 16, 2021
    NHN , Jan 16, 2021 :
    This is disgusting, why can't I connect to Giffgaff 5g without this setting but Three 5g SIM works of the bat with no adjustments needed.
    #81
    tobsin likes this.
  2. M1611419311658
    Cupcake Jan 23, 2021
    M1611419311658 , Jan 23, 2021 :
    Thanks so much for the detailed Tutorial but i still need some help. I managed to complete the process until step nr. 6. qpst wont recognize my op8pro. i have included a few screenshots to better understand my problem. thanks in advance
    #82
  3. M1611419311658
    #83
  4. F_Bruce_Thomason_thDF
    Cupcake Jan 25, 2021
    F_Bruce_Thomason_thDF , Jan 25, 2021 :
    On my Oneplus 8T, if I complete the tutorial, will this only work if I use the phone as a single sim phone? I still need the dual sim functionality so this is pretty pointless unless I can get both sims working. If not, I'll have to wait for the official OP update!!!
    #84
  5. luu123
    Cupcake Jan 28, 2021
    luu123 , Jan 28, 2021 :
    Iam on op8pro 11.0.3.3, O2 Germany and the only thing i need to do is to change preferred typ to "NR/LTE/TDSCDMA/CDMA/EcDo/Gsm/... in *#*#4636#*#*
    #85
  6. G_sky_fire_vcTO
    Cupcake Feb 5, 2021
    G_sky_fire_vcTO , Feb 5, 2021 :
    Yo man I did everything I followed the process and I watched the video to make sure,
    I didn't see the carrier policy xml subscription but I copied it anyway ,and I rebooted my phone ,and I still don't have 5G on my OnePlus 8T,I hope it's because of my sim card that doesn't support 5G but for now it doesn't seem to work,it does in the network settings show 5G is one of the networks that's available but still when I click it it doesn't work ,but thanks for the help man
    #86
  7. W1613242446608
    Cupcake Feb 13, 2021
    W1613242446608 , Feb 13, 2021 :
    [QUOTE = "jhoon_09, post: 22376346, membre: 2983427"] Bonjour,
    OnePlus n'a pas ajouté la 5G à la politique de l'opérateur sur OnePlus 7 5G, OnePlus 8 Pro et OnePlus 8.
    Voici la façon d'activer la 5G sur les téléphones mentionnés ci-dessus OS 11 - Android 11:
    Si votre OnePlus 8 pro, OnePlus 8 ou Oneplus 7T pro 5G ne se connecte pas à la 5G dans la zone couverte par la 5G.
    # Utilisez une seule carte SIM 5G dans l'emplacement numéro 1.
    Suivez les étapes ici:
    Conditions:
    1- Installez manuellement EngineerMode apk sur votre téléphone Oneplus:
    http://www.mediafire.com/file/2pr75mgbtq2xv2e/Engineeringmode_V1.01.0.17.apk/file
    2- Sur votre ordinateur, vous devez avoir le pilote OnePlus installé:
    http://www.mediafire.com/file/zkua1ob0dzaor09/OnePlus_USB_Driver_Setup.exe/file
    3- Application QPST. Veuillez trouver une application sur Internet:
    http://www.mediafire.com/file/2nb7d9k4vehvf7m/QPST_2.7.496.zip/file
    4- Les deux fichiers XML avec la 5G activée http://www.mediafire.com/folder/4l2vlenf869pu/5G_Carrier_Policy
    5- Pilotes Qualcomm.
    http://www.mediafire.com/folder/5mzfw32i8dlp5/Qualcomm Pilotes
    (décompressez les fichiers dans un dossier)
    6- Câble USB entre votre ordinateur et votre téléphone.
    Lorsque vous avez terminé et prêt:
    1- Allez dans Paramètres de votre téléphone - À propos du téléphone - Cliquez 8 fois sur le numéro de build.
    2- Retournez dans Paramètres - Option développeur - Activez le débogage USB.
    3- Sur votre téléphone, composez * # 801 # Utilisez le mode ingénieur puis mettez le bouton de mode ingénieur (ON).
    4- Connectez votre téléphone à votre ordinateur via USB.
    5- Allez dans Panneau de configuration - Gestionnaire de périphériques .. vous verrez deux périphériques inconnus.
    Faites un clic droit sur le premier - Mettre à jour le pilote - parcourir les pilotes de mon ordinateur - Permettez-moi de choisir parmi une liste de pilotes disponibles - cliquez sur Disque fourni .. - affichez tous les périphériques parcourir puis accédez aux pilotes Qualcomm que vous avez téléchargés précédemment. Ensuite, faites de même avec l'autre pilote inconnu. choisissez 9018 pour les deux pilotes inconnus.
    6- Ouvrez ensuite l'application QPST. Cliquez sur Ajouter un nouveau port dans le coin droit. s'il montre 2, ajoutez-les tous les deux.
    7- On the menu highlight the port which shows the (Phone Model) Open Start Clients then QPST EFS Explorerand wait until you see the files.
    8- Then go to policyman.
    9- In the policyman - right list, you will see two files: carrier_policy.xml and carrier_policy.xml_Subscription01. Copy them to your computer as a backup if you need them in the feature.
    10 - Now delete the two files (carrier_policy.xml and carrier_policy.xml_Subscription01) files from the policyman - right list.
    11- Now go to the tow XML files you already download earlier – 5G enabled network. Copy them to the policymandirectory , drop and drag one each time.
    12- Reboot your phone , your 5G is enabled now.
    13- Dial *#801# Use EngineerMode then put Engineer Mode Toggle (OFF).
    On OnePlus 8 and 8 Pro you may have to enable 5G NR via *#*#4636#*#* then Phone Information -> Set preferred network type. Choose:
    NR/LTE/TDSCDMA/CDMA/EvDo/GSM/WCDMA
    Or
    NR/LTE/TDSCDMA/GSM/WCDMA
    Enjoy the 5G speed .
    # All the requirements here:
    http://www.mediafire.com/folder/25yv56eyrevem/OnePlus_5G_OS_11
    Very Big Thanks to:
    1- Mr. Minh Truong:
    https://mt-tech.fi/en/modify-oneplus-7-pro-5g-8-and-8-pro-nr-lte-a-band-combos/
    2- Mr. Abdullah Alshehri :
    https://twitter.com/AdAlShehri737
    3- Evenshop Themobilestore – YouTube in French:
    [/QUOTE]
    #87
  8. W1613242446608
    Bonjour à tous,
    Pour tout les heureux propriétaire de ONE plus 8 (modèle IN2010), one plus vient de mettre en ligne une mise à jour qui permet d'avoir la 5G automatiquement, plus besoin de bidouille. Il s'agit de la version Oxygen OS 11.0.1.1.IN21AA
    #88
