11
Enable VoLTE and Wi-Fi Calling Android 11 on OnePlus 8 series and OnePlus 7 5G
  1. #41
  2. axbrandao
    Gingerbread Sep 8, 2021
    axbrandao , Sep 8, 2021 :
    Thank you very much, it worked on the OnePlus Nord N10 with Android 11. Operator TIM Brasil.
    #42
  3. GabrielSalbe
    Froyo Nov 10, 2021
    GabrielSalbe , Nov 10, 2021 :
    Hi, the process it is not working anymore? I am trying on and OXYGEN OS 11.0.11.11KBO5AA, but appears a error screen.
    #43
  4. astracd
    Gingerbread Dec 30, 2021
    astracd , Dec 30, 2021 :
    I did this procedure so many times on my last phones, but with 7T PRO 5G McLaren (T-Mobile) version something is still blocking it.
    IMS is registered and I get VoLTE available but it doesn't work.
    VoWifi is still showing unavailable for some reason.
    Not sure if this is normal but I don't see option in icon manager for status bar to turn on volte and wifi calling icons.
    OS: Android 11
    Carrier: Freedom mobile (Canada) mbn file is from pixel 4 for Freedom Mobile.
    #44
    V1642782178446 and tobsin like this.
  5. raaj.roop
    Eclair Jan 7, 2022
    raaj.roop , via OnePlus Nord CE , Jan 7, 2022 :
    There is another solutions by simple steps
    #45
  6. astracd
    Gingerbread Jan 7, 2022
    astracd , Jan 7, 2022 :
    And that is?
    #46
  7. saiamne
    Cupcake Jan 22, 2022
    saiamne , via OnePlus 7T Pro 5G , Jan 22, 2022 :
    Model HD1925 7T Pro McLaren edition
    .#800# does not have "functions switch"
    Settings for network has no VoLTE.
    Settings for display icons has no VoLTE.
    My carrier is kicking this phone off the network because it does not support VoLTE.
    Clearly it should be possible...?
    #47
  8. astracd
    Gingerbread Jan 24, 2022
    astracd , Jan 24, 2022 :
    1. You need older version of Logkit - you can find it in here
    https://forums.oneplus.com/threads/...ell-volte-and-vowifi-calling-working.1284987/
    2. it will show up once you activate it through old logkit
    3. T-Mobile version doesn't have these icons and I hate it for that, thinking of going back to 6T McLaren
    4. Not exactly sure what do you mean by "carrier is kicking phone off the network" are you losing connection all the time, or just volte doesn't work
    #48
  9. saiamne
    Cupcake Jan 24, 2022
    saiamne , via OnePlus 7T Pro 5G , Jan 24, 2022 :
    All voice-call network traffic will be exclusively over 4G bands beginning in February.
    Any device that sends or receives calls using 2G or 3G frequencies will no longer be able to make or receive phone calls.
    I may not have loaded that original LogKit correctly when I tried - I will reattempt
    Thank you
    #49
  10. raaj.roop
    Eclair Jan 24, 2022
    #50
  11. U1645507319087
    Cupcake Feb 22, 2022
    U1645507319087 , Feb 22, 2022 :
    hell guys it works only/till you keep the sim inside the mobile ..once you change the sim it has to be done again...do we have any permanent solution...
    #51
  12. sweizhong84
    Froyo Feb 26, 2022
    #52
  13. #53
  14. V1593527977049
    Cupcake Mar 30, 2022
    V1593527977049 , Mar 30, 2022 :
    Team has anyone had any success with sideloading logkit on Android 12. I seem getting error message.
    Without logkit I am not able to enable volte (option hidden).
    #54
  15. kairi033
    Cupcake Apr 2, 2022
    kairi033 , Apr 2, 2022 :
    same goes with me when I dial *#800# it shows a different menu and only for logging issues.
    #55
  16. W1586850179411
    Cupcake Apr 14, 2022
    W1586850179411 , Apr 14, 2022 :
    Is it same for the new oxygen os 12 in one plus 8 pro
    #56
