Enabling 5G on my 9 pro via OnePlus 9 Pro
  1. enaor
    Cupcake May 15, 2021
    enaor , via OnePlus 9 Pro , May 15, 2021 :
    Hi,
    I am not getting the option to select 5G on my 9 pro
    I'm on a 5G Network and my sim is provisioned to 5G by my carrier
    When I insert the same sim into S21 or iPhon12 I do get 5G.
    There must be a USSD code that enables this option on the 9 pro.
    Please help
    G_Barak_D likes this.
  2. Shailender Sharma
    Marshmallow May 15, 2021
  3. enaor
  4. McJader
    McJader , May 15, 2021 :
    Which country are you from?
    Caoimhín likes this.
  5. enaor
  6. McJader
    Which regional software build do you have?
    (And which regional variant of the device?)
    Caoimhín and G_plusone like this.
  7. enaor
    McJader likes this.
  8. enaor
  9. McJader
    It's the EU variant, so the 5G bands must be supported.
    I'll ask @Caoimhín to help you further since he must have the same model.
    Caoimhín and Shailender Sharma like this.
  10. Shailender Sharma
    Caoimhín and McJader like this.
  11. enaor
    Thanks. Please see the pic. No 5G option enabled
  12. enaor
  13. Shailender Sharma
  14. PhotoPicker
    The Lab Reviewer - OnePlus TV U1S May 15, 2021
    RohanSajeev and Caomhin like this.
  15. paramjit2001
    Gingerbread May 15, 2021
  16. MomZo
    MomZo , May 15, 2021 :
    Please let us know how you fixed the problem when you found a solution.
  17. G_Barak_D
    Froyo May 25, 2021
    G_Barak_D , May 25, 2021 :
    Have the same thing going on. Insert sim to galaxy s21 and 5G appears. Insert sim to op9 pro and no option available. Regarding bands - I double check the op9 pro do support my carrier. Is there a prement code that enable 5g option (even after reboot)?
  18. darkarvan , via OnePlus 9 Pro Stellar Black , Jun 3, 2021 :
    Try *#*#4636#*#* and select phone infos.
    Try to set the network mode to NR/LTE/TDSCDMA/GSM/WCDMA.
    OnePlus needs to enable 5G for your carrier in their carrier policy files otherweise it doesnt work. Thats software restriction.
  19. vipinpvarghese
    Honeycomb Jun 14, 2021 at 8:32 AM
  20. SteveHG
    Cupcake Jun 14, 2021 at 8:19 PM
