Encounter System UI Crash on Nord. via OnePlus Nord
  1. brajeshku8
    Cupcake Jun 14, 2021
    brajeshku8 , via OnePlus Nord , Jun 14, 2021 :
    I am one plus Nord user.Using this device since 9 months and after android 11 Update everyday facing a lot of bugs including System Ui crash 😠.Added the snapshot of the error in description.
  2. 乛SYCO乂X51
    Gingerbread Jun 14, 2021
    乛SYCO乂X51 , via OnePlus Nord , Jun 14, 2021 :
    It's a known issue.
    Try below steps and see if it helps
    - Go to play store
    - Disable auto update
    - uninstall updates from Android System WebView said:
    Try below steps for uninstalling Android System WebView updates,
    Launch the Google Play Store and go to My apps & games
    Open the “Installed” drawer and tap Android System WebView
    Tap Uninstall
    Confirm “Uninstall”
    Reboot device
    If above steps dint work, try below steps,
    Open system settings in your mobile > Apps & notifications > See all apps > Android System WebView > tap the three-dot overflow menu in the top-right corner > Uninstall updates > OK.
    Reboot your device
    Check if the issue is resolved or not
    sapanmittal likes this.
  3. sapanmittal
    Eclair Jun 18, 2021
    sapanmittal , via OnePlus Nord , Jun 18, 2021 :
    When will it get resolved completely??
  4. 乛SYCO乂X51
    Gingerbread Jun 18, 2021
