47
End of Open Beta release cycle for OnePlus 7T and OnePlus 7T Pro: OxygenOS 11 Open Beta 5
  1. Alex H. K.
    Froyo Jun 15, 2021
    Alex H. K. , Jun 15, 2021 :
    You see for yourself.
    At first I thought I had an electronically-physically broken phone.
    I read a few forums. Many users have exactly the same problems.
    This is not a coincidence. This is the fault of the software.
  2. Louisbaecke510
    Ice Cream Sandwich Jun 15, 2021
    Louisbaecke510 , Jun 15, 2021 :
    i don't think so ;)
    McJader likes this.
  3. zer0se7en
    zer0se7en , via OnePlus 7T , Jun 15, 2021 :
    That's T-Mobile variant! Looks like you're going to be stuck to what they will release for it coz OnePlus is not in control of T-Mobile OS update releases even if it's sim free. Chances are if you flash any update you can download (India/EU/Global), your device will show tha you did not flash the right OS. It will work, vut with problems.
    If you haven't opened it, do not open it.
    If you can give it back, do it!
    T-Mobile sucks in providing updates more than OnePlus itself.
  4. Alex H. K.
    Froyo Jun 15, 2021
    And I have proof of that!
    I have installed a different Ambient Display.
    It worked without a problems. No red ones :(
    Unfortunately, I like only the originals. Not fakes!
  5. Louisbaecke510
    Louisbaecke510 , via OnePlus 7T Pro , Jun 15, 2021 :
    Me works
  6. Deactivated User
    Jun 15, 2021
  7. zer0se7en
    No one says you should. A "Problem" is relative. For us users sometimes any problem is not a problem.
    I have a "cheaper" 7T so I wouldn't know how to look for a workaround to your problem about AOD. Maybe if we talk about the CHEAP 7T then I can help you.
    About the sounds being a bit muted after a period of time after a reboot, yes I noticed that. But I do not consider it a problem coz my notifications are still as loud as how I've set them. (Hence the meaning of what I said at the beggining of this quote)
    About the battery, I am still experiencing almost the same SoT from how it was since I purchased it Dec 2019. 8hrs+ max Wifi only and 5hrs max when Data on. As I typed this msg I am now at 6hrs SoT with still 31% battery left.
  8. zer0se7en
    Yes. This needs to be confirmed. What I know was just something I've heard and read not experienced. But if you ask me, I will never get that model variant. If I'm in the US I will get the HD1905 North American variant.
  9. Deactivated User
    Jun 15, 2021
  10. Louisbaecke510
    between 8 months and 1,2 year they stop produce a serie so
  11. zer0se7en
    Are you a member on XDA? Aside from tech support here, try to also msg some OnePlus guys there. I'm sure they have answers. Or back in Reddit. I'll PM you if I get a reliable info.
  12. T1606405635732
    Cupcake Jun 15, 2021
  13. Deactivated User
    Jun 15, 2021
  14. Alex H. K.
    Froyo Jun 15, 2021
    zer0se7en, what are your ideas? :)
  15. ghostofcain
    Marshmallow Jun 15, 2021
    ghostofcain , Jun 15, 2021 :
    Do your issues persist in safe mode?
  16. Alex H. K.
    Froyo Jun 15, 2021
    Yes, in Safe Mode, 1x phone responded to Wake Up. Ambient Display not even once.
    The sounds are at normal volume.
  17. Louisbaecke510
  18. ghostofcain
    So if sounds remain normal in safe mode the issue isn't with the ROM. But as for the ambient and tap to wake I'm clueless it didn't affect me in 11.0.1.1
    Alex H. K. likes this.
  19. Alex H. K.
    Froyo Jun 15, 2021
    Thanks ghostofcain!:)
    It remains to wait for the OP to start working and fix these months-old errors.
  20. ghostofcain
    Hopefully the feedback you filed will help, I understand that for users suffering these issues it's a right PITA, but the fact that not all users are suffering points to the fix possibly being more than a simple tinkering with the code.
