45
End of Open Beta release cycle for OnePlus 7T and OnePlus 7T Pro: OxygenOS 11 Open Beta 5
  1. zer0se7en
    Ice Cream Sandwich Jul 24, 2021
    zer0se7en , via OnePlus 7T , Jul 24, 2021 :
    Open Beta 5 came after Stable 11.0.1.1 makes the OB5 newer so you cannot flash over it. Wait for a new Stable release then.
    I've never tried downgrading then using KeepData apk yet to retain all datas so I wouldn't recommend it.
  2. zer0se7en
    Sorry, was that a good thing or a bad thing? I really have no idea coz I dont use it😅.
    If you want how Canvas on Stable build should be, just reflash the Stable again. Since you are already on Stable build, your data will not get wiped automatically anymore.
    Chinaboy5216 likes this.
  3. Shubham8550
    Froyo Jul 24, 2021
  4. Chinaboy5216 , via OnePlus 7T Pro McLaren Edition , Jul 24, 2021 :
    To be honest I also don't use it and find it even useless but for sure there's people that like it so I thought why not mention it here.
    By the way, since I changed to bug stable now my system storage is showing 58Gb. What a waste of good storage, been checking for days, weeks, months but nothing really useful nor working found to reduce this shit.
    Amazing how fast it eats away perfect storage space...
  5. Chinaboy5216 , via OnePlus 7T Pro McLaren Edition , Jul 24, 2021 :
    Shows clearly how much they care about us users... They have our money in the pocket and we have decent hardware left but that's also the only thing we have left now.
    Anyway time to move on and forget 1 OPPO plus. They don't care about us anyway, only that matters anymore is $$$
  6. mohitverma119
    Donut Jul 24, 2021
    Shubham8550 likes this.
  7. kãräñ_90564
    kãräñ_90564 , via OnePlus 7T , Jul 24, 2021 :
    Really, This is absolutely unfair for 7t series. 7t series is latest and recent model than from 7 series. Then why they closes beta for both series at same time.
    This is really unfair, bad luck for 7t series users. Huge disappointment....
  8. GGanesh
    Eclair Jul 28, 2021
  9. pedritopl
    Gingerbread Jul 28, 2021
    pedritopl , Jul 28, 2021 :
    Man! That was the best OnePlus related news I read in months (maybe challenged only by the new unofficial TWRP for 7T).
    I just successfully updated from OB5 to 11.0.2.1 keeping root and my data (update->Magisk->KeepData). For the moment all works fine. We'll see in the next days if there are any hidden problems due to unsupported update process.
    Thanks!
    zer0se7en likes this.
  10. zer0se7en
    Ice Cream Sandwich Jul 28, 2021
    zer0se7en , via OnePlus 7T , Jul 28, 2021 :
    You are most welcome 😁
    Don't worry, all will work as it should. If when in doubt, just reflash the update again. You won't be needing keepdata app this time anymore coz you are already on Stable. Surely you know how to re-root so this won't be a hassle.
    This is what I always do after doing the keepdata method just to be sure all update properties are installed or flashed correctly.
    pedritopl likes this.
  11. pedritopl
    Good point. I just flashed it again (yes, I kept root:) ).
    I'm glad I delayed the decision to move to stable until now and saved myself all the hassle of clean flash.
    Thanks again!
  12. sinsticon
    Cupcake Jul 29, 2021
    sinsticon , via OnePlus 7T , Jul 29, 2021 :
    Would love to hear from you on battery and performance improvement. I am also on OB5 planning to move to 11.0.2.1 soon
  13. pedritopl
    Gingerbread Jul 29, 2021
    pedritopl , Jul 29, 2021 :
    We'll, it's just been one day, so not very conclusive, but I'm quite happy with the result. Battery life *seems* slightly better, phone runs smoothly and I haven't noticed any unexpected problems till now. More days / charging cycles needed to make sure.
  14. nikhil92
    Froyo Jul 30, 2021
    nikhil92 , Jul 30, 2021 :
    wtf ppl you do to my phone i am not able to connect to wifi after installing this build
    did every i can reset format hard reset -- shit cant even use my phone any more
    wtfffffffffffffffffffff why???????????????? so pissed off
  15. Kaushik_B1986 , via OnePlus 7T Pro , Jul 31, 2021 :
    Hi All, I recently took a 7T pro and the Android version is showing 11, however the Build number is 02_Beta_5.
    So, will the stable Oxygen OS 11.0.2 will come automatically as OTA or do I have to do anything?
  16. ghostofcain
    Marshmallow Jul 31, 2021
    ghostofcain , Jul 31, 2021 :
    So you installed a beta build, and it doesn't work no big deal surely? This is a beta for testing purposes, file the requisit feedback and then rollback to stable build.
  17. Sam197
    Jelly Bean Aug 2, 2021
    Sam197 , via OnePlus 7T , Aug 2, 2021 :
    To switch back to stable version,you have to get A10 stable then update it to A11 stable of you want.
    Keep in mind that every time you switch between the two channels,it would erase everything in your phone,so back up first before you do anything.
    Kaushik_B1986 likes this.
  18. Kaushik_B1986 , via OnePlus 7T Pro , Aug 2, 2021 :
    Thanks a lot for the headsup mate!!
    Sam197 likes this.
