Endoscope USB or Wifi not detected by OP7T Need App Recomendation
  1. PaulRWC
    Cupcake Jan 28, 2021
    PaulRWC , Jan 28, 2021 :
    I have a endoscope that does not work with my OP7T. I have tried several Apps both WiFi and USB but none seem to work. The camera is never detected. When I plug it in using the USB port the light does come on but no video. Could anyone recommend an App that is working on a OP7T. The camera works on my Windows 10 system using the USB connection.
  2. drl431
    Community Hero 2020 Jan 28, 2021
    drl431 , Jan 28, 2021 :
    Try turning on the OTG switch in the system settings.
    Caomhin likes this.
  3. PaulRWC
    Cupcake Jan 29, 2021
    PaulRWC , Jan 29, 2021 :
    I just tried that with no effect.
    Several Endoscope Apps I have tried keep shutting down. I am using a micro USB to Type-C connector. The light on the endoscope comes on and Windows sees my phone when I use the adapter to connect it to my Windows computer.
  4. Dsquared1955 , via OnePlus Community App , Jan 30, 2021 :
    Try going to settings\bluetooth and device connections when you have the scope connected. At the bottom of the page is a USB setting; the default is no file transfer.
    Changing the action may be the answer.
  5. Bhaveee
    Honeycomb Jan 30, 2021
    Bhaveee , via OnePlus 7T , Jan 30, 2021 :
    Try to switch to midi device as midi stands for musical instrument digital interface.
    Dsquared1955 likes this.
