Enhanced LTE option not visible in Oneplus 2
Is anyone still using OnePlus 2
Poll closed Friday at 11:24 AM.
  1. Yes
    1 vote(s)
    100.0%
  2. No
    0 vote(s)
    0.0%
  1. Chitraranjan Urs V
    Cupcake Feb 23, 2021
    Chitraranjan Urs V , Feb 23, 2021 :
    Hello,
    Does anyone still facing the issue with LTE on Oneplus 2 device ?
    I have Oxygen OS Version 3.6.1 and I don't see Enhanced LTE option under sim and networks.
    I have issue using data with New VI sim.
    I have tried setting network type as LTE only by *#*#4636#*#* method, but with this I neither get any calls nor I can make any. But with other options I cannot use the phone to just even browse the internet.( I get Edge signal with an exclamation symbol) i can just make calls and send texts.
    Same SIM works perfectly fine on other devices. Also I used Airtel sim in Slot 1 and it works fine
    Basic trouble shooting steps like deleting the phone cache have been performed.
  2. Caomhin
    Community Hero 2020 Mar 2, 2021 at 9:32 PM
    Caomhin , via OnePlus 6T , Mar 2, 2021 at 9:32 PM :
    Not sure if this can work on a OnePlus 2 as the OOS may be too old, but might be worth a try.
    This is for all OP phones, however it discuses the 8 Series, but it should apply to any series as the protocols are the same.
    [GUIDE] Enable VoLTE & VoWiFi on all devices NO ROOT.
    https://forum.xda-developers.com/on...nable-volte-vowifi-devices-root-t4105817/amp/
    Log Kit 1.0
    https://www.apkmirror.com/apk/onepl...ase/onepluslogkit-1-0-2-android-apk-download/
    There are newer versions but I would suggest trying this with the details provided on XDA.
    If you do try the suggestions. Let us know how you get on.
    rhyd1am likes this.
  3. rhyd1am
    KitKat Mar 2, 2021 at 10:00 PM
    rhyd1am , via OnePlus Community App , Mar 2, 2021 at 10:00 PM :
    I was never able to get VoLTE working on my OP2, until I rooted and flashed Havoc OS. Not 100% sure, but I seem to remember Lineage OS had VoLTE working as well.
    I suspect you're correct that this may not work with his version of OOS.
    Be interested to see if it does work though.
    Caomhin likes this.
  4. Caomhin
    Community Hero 2020 Mar 2, 2021 at 10:06 PM
    Caomhin , via OnePlus 6T , Mar 2, 2021 at 10:06 PM :
    Thought it might be worth a try to see if it will function on the OP2
    rhyd1am likes this.
  5. rhyd1am
    KitKat Mar 2, 2021 at 10:08 PM
    Caomhin likes this.
