495
[ENTRIES CLOSED] #PMChallenge – Design our next OxygenOS Feature
  1. prabhugfx
    Cupcake Feb 7, 2019
    prabhugfx , Feb 7, 2019 :
    The UI Should be like this.....
    not to be copied but look similar like this....
    because its Oneplus.....
  2. jaspinder singh
    Cupcake Feb 7, 2019
  3. faheemuddin_md
    Cupcake Feb 7, 2019
    faheemuddin_md , Feb 7, 2019 :
    1) Add the feature for the notification bar by swiping down from the mid screen area that allows notification bar helps the lot of members who are having discomfort while stretching their fingers.
    2) Add face recognition for the app security also.
    3) Add more screen lock gestures with customizable.
  4. Atharva Mithe
    Donut Feb 7, 2019
    Atharva Mithe , Feb 7, 2019 :
    Oneplus must include these features
    1) default barcode scanner in camera app,
    2) Default in build AdGuard Family Protection DNS installed which will make wifi and Mobile data safe and Adult content p*rn free. So no need of Adblock app and vpn as online transactions fails because of 3rd party adblock app.
    3) Oneplus cleanup and antivirus app and optimization app
    4) Default Caller Id Finder installed via Truecaller API means it identify calls from truecaller database.
    5) In build OPT copy option directly from notifications in the default messenger app which it currently lacks. Means Just like Kyte AI SMS app from play store or make this app default messaging app, so that we don't have to disable the default oneplus msg app.
    6) Oneplus Keyboard
    7) Oneplus notes cloud backup like Google keep. It lacks cloud backup.
    8) And FM radio in Oneplus devices.
    9) A feature to select 4G or 2G connectivity for each sims individually as Moto G4 plus network option.
    P1510675205208 and Saniubah75 like this.
  5. H1542281644217
    Cupcake Feb 7, 2019
    H1542281644217 , Feb 7, 2019 :
    Create a inbuilt mobile number identification system in oxygen os and blocking system for advertising calls or harassment calls
  6. Aleynikpavel
    Cupcake Feb 7, 2019
    Aleynikpavel , Feb 7, 2019 :
    Я пользуюсь oneplus 6. Я вынужден использовать Google camera, как приложение для съёмки видео. В этом приложении можно выбрать многие функции включая количество fps, mbps, разрешение видео. И самое главное угол обзора видео как при съёмки фото.
    Сделайте пожалуйста, удобный интерфейс в камере для съёмки видео, очень не удобно и мало функций.
  7. yogesh5727
    Gingerbread Feb 7, 2019
    yogesh5727 , Feb 7, 2019 :
    please launch OnePlus Excel PDF word PowerPoint and all such applications exclusively for users soon it's very important and useful for daily use as well... thank you...
  8. T1547663499470
    Donut Feb 7, 2019
    T1547663499470 , Feb 7, 2019 :
    I can only think of one major missing part of software for me . Coming from an iPhone I miss so much live/motion photos .please add to the stock camera .Otherwise great phones great OS!
    Saniubah75 and yogesh5727 like this.
  9. cgarg
    Cupcake Feb 7, 2019
    cgarg , Feb 7, 2019 :
    Hi
    Not able to create a new thread, showing following error
    OnePlus Community - Error
    You do not have permission to view this page or perform this action.
    Please help.
    Thanks.
  10. Saniubah75
    Saniubah75 , Feb 7, 2019 :
    how i wish i can be part of it. terms and conditions are very huge for amateur like us. oneplus need to consider us. thank to oneplus team. i love them all. I'm now using oneplus 6t coming from oneplus 5.
  11. mahyunk
    Froyo Feb 7, 2019
    mahyunk , Feb 7, 2019 :
    Sorry for being late,
    Do we have to create a separate thread for each idea or we can combine all of them into one?
  12. 7719953069
    Cupcake Feb 7, 2019
    7719953069 , Feb 7, 2019 :
    I think in oxigen os need a one pre install VPN changer .....
    Its maybe a total new feature for oxizen os...
  13. akshay8055
    Cupcake Feb 7, 2019
  14. Kundan28
    Cupcake Feb 7, 2019
  15. puneet349
    Cupcake Feb 7, 2019
    puneet349 , Feb 7, 2019 :
    1. OWN MUSIC PLAYER WITH EQUILIZER AND CUSTOMIZATIONS.
    2. FACE UNLOCK ON LOCKED APPS
    3. ACCEPT CALLS THROUGH HOME BUTTON.
    4. CREATE DIFFERENT PROFILE WITH CUSTOM NAMES FOR ALERT SLIDER.
    5. STEREO SPEAKERS.
    6. APP HIDER WITH LOCK.
    7. SYNCING WHATSAPP IMAGE WITH DIALER'S .
    8. ONEPLUS ASSISTANT [e]1f60d[/e]
    9. SINGLE HAND MODE WITH NO NAVIGATION BAR.
    10. SHOW ESTIMATE CHARGING TIME.
    P1510675205208 likes this.
  16. F_Manoj_Jaiswal_xhSM
    Cupcake Feb 7, 2019
  17. Asuras_6T
    Donut Feb 7, 2019
    Asuras_6T , Feb 7, 2019 :
    How about adding the ability to change system font without having to root and install Magisk add-ons.
    I really don't understand why this isn't a standard feature on all phones.
  18. F_Manoj_Jaiswal_xhSM
    Cupcake Feb 7, 2019
  19. PTuT
    Jelly Bean Feb 7, 2019
    PTuT , Feb 7, 2019 :
    I would like to see slow sync flash where flash would be executed but then longer shutter speed would be used to get well exposed shot at low-light sittuation. Problem with current low-light shots is that when flash is used then faces/close objects are bright and background is lost/dark. This could be tight to OIS.
  20. sutharje
    Cupcake Feb 7, 2019
    sutharje , Feb 7, 2019 :
    please develop complete ecosystem like iPhone especially iTunes to backup all data and software update . this will add premium feel and uniqueness in the Android flood.
