495
[ENTRIES CLOSED] #PMChallenge – Design our next OxygenOS Feature
  1. prabhugfx
    Cupcake Feb 7, 2019
    prabhugfx , Feb 7, 2019 :
    Just Press and Hold on Home Screen and this Menu will Appear.....
    Just tick the above mentioned option
  2. 9655702514
    Cupcake Feb 7, 2019
    9655702514 , Feb 7, 2019 :
    1.If you have a phone with a thief (one plus )phone in simple of phone off mode long press key button. new idea for key long press lock key switched off option click verifying the password after phone switched off of the phone
    2.benefite for the thief don't switched off OnePlus phone.oneplus users checking for location after catching for thief
    3.if I once miss the mobile phone i can get it back immediately from the thief
    4. ?
    WolneySilvaJr and A4ali like this.
  3. Praveen.b
    Cupcake Feb 7, 2019
    A4ali likes this.
  4. norycom
    Donut Feb 7, 2019
    norycom , Feb 7, 2019 :
    i would like the option to create folders on app drawer and password protected hidden area
  5. selvaganapathy07
    Cupcake Feb 7, 2019
    selvaganapathy07 , Feb 7, 2019 :
    Hi, I'm a big fan of OnePlus gestures, but it is not the best if we compate to others. like to go back we swipe from bottom right instead we should have a feature to swipe from the right edge of the phone....i used poco and found this easy
  6. alexw0w
    Cupcake Feb 7, 2019
    alexw0w , Feb 7, 2019 :
    My proposition:
    Face unlock should make screen white and full bright @ night to help phone to unlock.
  7. G_ĶĦêiʀ_-Ęddİnể_PUQA , Feb 7, 2019 :
    I want you to add an application for music from your company and not imposed by Google with the Android for the user to have a wonderful experience listening
    Ruben. likes this.
  8. F_Satpal_Singh_Ahujaa_qV
    Cupcake Feb 7, 2019
  9. Sunnyanand69
    Cupcake Feb 7, 2019
  10. G_edilson_sousa_Irrh
    Cupcake Feb 7, 2019
    G_edilson_sousa_Irrh , Feb 7, 2019 :
    I currently use three launches, oneplus, pixel and Microsoft, the latter of which I like the most, the oneplus by fluency, pixel, Google and Microsoft feed by personalization, suggestion: add Google feed and customize such as the Microsoft launcher ... folders, hidden icons and home screen borders
  11. N1543900302026
    Cupcake Feb 7, 2019
  12. Himkshu
    Cupcake Feb 7, 2019
    Ruben. likes this.
  13. N1543900302026
    Cupcake Feb 7, 2019
    Ruben. likes this.
  14. Nurbar
    Cupcake Feb 7, 2019
    Nurbar , Feb 7, 2019 :
    I suggest that the central position of the alert slider allows to keep the phone in vibration except for the apps that can be manually selected so that they can emit sounds. a greeting!
  15. Amirulirfn
    Cupcake Feb 7, 2019
    Amirulirfn , Feb 7, 2019 :
    :)Please make a pc mode like dex mode but better, good for users that dont want to carry laptop everywhere.
    Integrate more google apps like google pay, assistant, because making more apps like that will annoy every android users and will be called bloatware.
    More software updates than google pixel
    Make a better app than garageband on ios.
  16. X1541169733152
    Cupcake Feb 7, 2019
  17. Ruben.
    Cupcake Feb 7, 2019
    Ruben. , Feb 7, 2019 :
    Make a option to disable the Oxygen theme (to get pure Android)
    Talhamubarik likes this.
  18. udit yadav
    Cupcake Feb 7, 2019
    udit yadav , Feb 7, 2019 :
    the power button and volume up & down both button merge in single button for save the side area of phone
    details blow PDF. file
  19. dustyash
    Cupcake Feb 7, 2019
    dustyash , Feb 7, 2019 :
    An IFTTT like option. Motorola used to have a routine feature. A good example of this would be if Android Auto launches start a radar detector app or if it's a specific time of the day automatically put your phone in silent/do not disturb.
  20. Sujan rao
    Froyo Feb 7, 2019
    Sujan rao , Feb 7, 2019 :
    kudos to Oneplus!
    My suggestion for #PMCHALLENGE
    Slomotion editing feature as on Apple devices and ability to screen record.
    and Last one is a request to please edit the notification panel so that it takes less space when we drag down
