495
[ENTRIES CLOSED] #PMChallenge – Design our next OxygenOS Feature
  1. G_Luis_Jaimes_zRGO Cupcake Feb 18, 2019
    G_Luis_Jaimes_zRGO, Feb 18, 2019 :
    #PMChallenge
    Intenté registrarme, pero no me deja crear nuevos hilos y no estoy seguro si este mensaje sera leído...
    Aunque no podre participar en el concurso, espero que si puedan mejorar su apartado multimedia, en especial la reproducción de audio y contar con un DAC decente... Tenia buenas ideas, pero si logro crear un post decente se las haré llegar.
  2. Ruby G. NA Community Manager Staff Member Feb 19, 2019
    Ruby G., Feb 19, 2019 :
    Si tu estas un nuevo usuario, puedes crear un nuevo hilo en el sección
    "Starting point" aqui: https://forums.oneplus.com/forums/starting-point/
    Tambien @One_Will9 es de OnePlus España y puede hablar español si tu tienes mas preguntas. Buena suerte!
  3. Ruby G. NA Community Manager Staff Member Feb 19, 2019
    This is a very cool idea! Hope you make a new thread entry so that it can be considered!
    alessiodales likes this.
  4. Hassan Momin Cupcake Feb 19, 2019
    Hassan Momin, Feb 19, 2019 :
    My Current phone is OnePlus 6T
    Some few suggestions from my side
    1) Add more fonts
    2) Add more themes
    3) customize home screen & app drawer like NOVA launcher
    4) customize Navigation gesture actions right-edge left-edge like FLUID Navigation gesture
    5) Create OnePlus own keyboard
    6) PIN for power off
    Bharath1991 likes this.
  5. E1515061349520 Donut Feb 19, 2019
  6. G1535458289027 Donut Feb 19, 2019
    G1535458289027, Feb 19, 2019 :
    we can have a video app which helps in watching videos of all formats. now we depend on third party app. we also need the clear cache option in settings, which was easy to clear cache memory.
  7. Ramesh_95 Cupcake Feb 19, 2019
    Ramesh_95, Feb 19, 2019 :
    1.OnePlus launcher is not smooth when compared to Stock Android UI..Please make the feel of touch while using Oxygen OS.
    2.Front Camera clarity is worst in department of Image processing ..Please look into it and improve sharpness of Images when taken with Front Camera (OnePlus 6)
    3.Provide us the inbuilt screen recording feature to capture gameplays
    S1529763229144 likes this.
  8. saumyajyoti_mukherjee Cupcake Feb 19, 2019
  9. JusTy_ Donut Feb 19, 2019
    JusTy_, Feb 19, 2019 :
    My Suggestion is to improve the Alarm Clock or introduce new one. Currently if I have a daily alarm, and if I just want to disable it for a day or for some days, I can't do it automatically. I have to do it manually. Like disable it and then always have to remember when to enable it again. If we somehow missed it, we will miss the alarm when we actually needed it the most.
    Who are the users?
    Every single OnePlus users.
    What is the proposed function?
    When I disable a daily alarm, it should give me three option in pop-up.
    1. Disable (This will act as manual mode)
    2. Disable it for Tomorrow/Today (depending on which time I am doing this)
    3. Scheduled It. (This will help us for more than one days, and trust me this will be very useful)
    Additionally it will be awesome to get this integrated with Google Assistant.
    What is the user value?
    This will help every single OnePlus users to avoid unexpected alarm miss. No longer we have to remember when to re-enable the alarm.
    If there are existing comparable functions in the smartphone industry, how is your proposed feature superior?
    I am not sure, I don't find this anywhere else.
    Note : I don't think any design is required for this.
  10. JusTy_ Donut Feb 19, 2019
    Barcode scanner is there in integrated Google lenses.
  11. Bharath1991 Eclair Feb 19, 2019
    Bharath1991, Feb 19, 2019 :
    I am still waiting for screen recording feature on our oneplus phones.
    And it will be even better if we also have sms scheduling feature.
    I1548478563142 likes this.
  12. Bharath1991 Eclair Feb 19, 2019
    it's better to change our navigation gestures it's always tough to reach the bottom to go back.
  13. F_Harshith_Beeravolu_WME Froyo Feb 19, 2019
  14. V1532181727068 Donut Feb 19, 2019
    V1532181727068, Feb 19, 2019 :
    Screen recording is the best option that can one plus appy for it customers,we a screen recording option which is fast and efficient
    Thanks for giving me such a golden opportunity
  15. Arun_R Froyo Feb 19, 2019
    Arun_R, Feb 19, 2019 :
    no antivirus or cleaning app is needed!
  16. 7873889339 Donut Feb 19, 2019
  17. G1521040589194 Cupcake Feb 19, 2019
  18. Akshay_oswal Cupcake Feb 19, 2019
    Akshay_oswal, Feb 19, 2019 :
    I m using oneplus 6t for last 2 months and I think you should add a radiation control option.
    Which will make a plus point to attract customer to your brand.
  19. Imsahu Froyo Feb 19, 2019
    Imsahu, Feb 19, 2019 :
    The most important feature i need is
    No power button menu ,no quick toggles should be accessible on locked device.If the phone is lost then no one can turn on airplane mode,no one can turn off phone
  20. D1541491648716 Cupcake Feb 19, 2019
