5
Equalizer In Settings
  1. mhz99fb
    Donut Jul 13, 2017
    mhz99fb , Jul 13, 2017 :
    It's only good for wired headphones but I want to use my Bluetooth headphones with Spotify and I want to change the audio but the audio switch option is greyed out. I really wish that this would work but it doesn't
    PLEASE FIX THIS!!! THANK YOU!!
  2. Antman33
    Cupcake Jul 13, 2017
    Antman33 , Jul 13, 2017 :
    What are you trying to EQ. Usually line level audio into a decent pair of headphones will sounds very true to the recording. Keep in mind Spotify uses compression algorithms so you will never hear analog quality audio via Spotify.
    eye842 likes this.
  3. sepu79
    Gingerbread Jul 13, 2017
    sepu79 , Jul 13, 2017 :
    you need to go phone settings/sound and scroll down.there is a eq.
    yoursdjay likes this.
  4. sepu79
  5. kpoyser
    kpoyser , Jul 13, 2017 :
    I'm able to use the OP3T EQ with my BT headset, makes a lot of difference even with Spotify
  6. Rodriguezz
    Gingerbread Jul 14, 2017
    Rodriguezz , Jul 14, 2017 :
    The addition of an EQ is welcome, but OnePlus way of doing it, is practically useless. You can´t use the system´s EQ with Bluetooth audio, and if you use it with wired headphones, there´s this "general enhancement" thing that you can´t turn off, and is just garbage, not to mention the ridiculous sounding and WTF presets. Of course you can just leave it off, but OnePlus could make way for third party audio DSP´s to work inline with OOS, because there are some good ones floating around, but alas, no. Only way out is root or an audio player with all the bells and whistles.
  7. eye842
    Lollipop Jul 14, 2017
    eye842 , Jul 14, 2017 :
    Both Spotify and Bluetooth audio is low quality (max 320kbps) and the blocking of adjustments can be because of that - sound is not improvable.
  8. kpoyser
    kpoyser , Jul 14, 2017 :
    to get the EQ to work with BT plug in wired headphones, turn on the EQ in sound settings, unplug headphones now when you enable BT the EQ will be on and as for the person who said it won't make a difference with Spotify, GARBAGE! Just make sure to choose the right EQ setting for your tastes
  9. fastfreddy68
    Cupcake Oct 5, 2019
    fastfreddy68 , Oct 5, 2019 :
    Still would be better if you could disable I have a much better third-party EQ but can't use it on this phone. One plus is unimpressive.
  10. T1577174467978
    Cupcake Aug 28, 2020
    T1577174467978 , Aug 28, 2020 :
    Bluetooth audio issue...when I increase volume..it doesn't increase gradually...I'm facing this issue from when I reset my equalizer in settings..plz can anyone help me in getting back to initial equalizer settings in OP7pro..?
    Equalizer ratings from left....
