Y1582011974368 , via OnePlus 9 , Jan 28, 2022 : Anyone facing issue in Instagram notification after software update??
Swejuggalo , Jan 28, 2022 : There was some post about that yesterday. Don't recall the details. But I normally revert to defaults by wiping data on apps that don't work normally and log in again.
Y1582011974368 , via OnePlus 9 , Jan 28, 2022 : I tried Still not sure what's the issue Anyway thanks 👍
Y1582011974368 , via OnePlus 9 , Jan 28, 2022 : Even with app lock one can see the content in the notification For instance if WhatsApp is locked i get the msg notificatio One can read msg from notification Wasn't the case before update
Swejuggalo , Jan 28, 2022 : So you don't want to see the notification content unless unlocking? Can't find the way to unhide it myself 😜
Swejuggalo , via OnePlus 9 Pro Morning Mist , Jan 28, 2022 : Found it. Does this setting get overrided?
Swejuggalo , via OnePlus 9 Pro Morning Mist , Jan 28, 2022 : Other apps have hidden content but not Instagram?
Y1582011974368 , via OnePlus 9 , Jan 28, 2022 : Problem still not resolved 😟 Thank you so much for your time
Swejuggalo , via OnePlus 9 Pro Morning Mist , Jan 28, 2022 : I added Instagram to App Lock. I can't see the content. Neither on the lockscreen (allowing all other apps) nor when having unlocked the device.
Swejuggalo , via OnePlus 9 Pro Morning Mist , Jan 28, 2022 : What if you remove the app lock on Instagram and add it again?
Y1582011974368 , via OnePlus 9 , Jan 28, 2022 : Before this update once you unlock the app you can see the content but now you have to open and you are straight into msg window Is it so?
Swejuggalo , via OnePlus 9 Pro Morning Mist , Jan 28, 2022 : With app lock is used it remains as hidden content in banner and lockscreen. When I open Instagram it opens as I left it. I don't normally use Instagram. So I don't really know what else to expect.
Xcommunicad0 , via OnePlus 8T , Jan 29, 2022 : 12 update is turning out like a maze even for simple customisations... I guess the app designers and architects have forgotten the user friendliness.
