Ethernet issue. OnePlus tv Y series. via OnePlus 8T
  1. G_sushil_lepcha_igYD , via OnePlus 8T , Jan 22, 2022 :
    My OnePlus tv when connected through ethernet (jiofibte) . It shows connected but there is absolutely no Internet connection. No apps will open. When connected through WIFI, everything is ok.
    I checked cable and I check the ethernet port of jiofibre router also. Everything is fine. Other devices like laptops gets internet without any problem ,when using same port or cable. It is just the tv.
    What could be ther issue?
  2. Venky61
    OnePlus TV Expert Community Expert Jan 23, 2022
    Venky61 , Jan 23, 2022 :
    Hi,
    Strange issue.
    Do one thing. Turn off the Power of the TV and remove the power cord and connect it back after 10 min.
    If that doesn't help, go with a Factory reset.
    Hope one of the above helps.
    Tokolozi likes this.
  3. G_sushil_lepcha_igYD , via OnePlus 8T , Jan 27, 2022 :
    Did everything. Nothing works.
