ethernet/lan
  1. SHIKARIII
    Froyo Dec 20, 2018
  2. SHIKARIII
    Froyo Apr 6, 2020
  3. Cervantes
    Moderator Moderator Apr 6, 2020
    Cervantes , Apr 6, 2020 :
    Hi
    what do you want to do
    what do you want to connect
  4. SHIKARIII
    Froyo Apr 6, 2020
    SHIKARIII , via OnePlus 6 , Apr 6, 2020 :
    I want to connect Ethernet cable for internet! like lan wire to adapter and to use internet
  5. Cervantes
    how can you do that
    the phone has a micro usb type c connector
    for you to connect to which device
    Artemus. likes this.
  6. SHIKARIII
    Froyo Apr 6, 2020
    Go to amazon and write type c to Ethernet adapter you'll get to know buddy
  7. ngydat
    Lollipop Apr 6, 2020
    ngydat , Apr 6, 2020 :
    Still. It won't probably work. I mean, other users have already asked the same type of question for HDMI connectivity and if I remember right, they told it didn't work. But you're welcome to try : it's the only way you'll know for sure.
    Artemus. and G_honey_tiwari_ewgq like this.
  8. Cervantes
    I understand what an adapter is
    you have internet on the phone and you want to give internet to which device
    in amazon you find a thousand devices
    some may be compatible and some are not compatible
  9. SHIKARIII
    Froyo Apr 6, 2020
    thanks for helping brother you're right
  10. SHIKARIII
    Froyo Apr 6, 2020
    Thank you
    much needed...
  11. tide1109
    Jelly Bean Apr 6, 2020
    tide1109 , via OnePlus 6 , Apr 6, 2020 :
    No, the OnePlus 6 and i think every other OnePlus device does not support ethernet in OxygenOS.
    The feature could be enabled with a different kernel. It's only software that doesn't allow ethernet.
    Obviously you need an adapter for ethernet.
    The HDMI out functionality that was also mentioned is only supported on the OnePlus 7 and newer. This includes the Pro and non-Pro models. A different software like a kernel can't fix this.
