2
Excellent 3rd party tempered glass for the 6T!
  1. bpwest80 Jelly Bean Jan 3, 2019
    bpwest80, Jan 3, 2019 :
    Comes with a little brush, 2 brushes and 2 packs of glue. Get your tempered glass lined up like you want it and brush the glue around the edges last.
  2. G_Andrew_DuLac_InWk Donut Jan 3, 2019
    G_Andrew_DuLac_InWk, Jan 3, 2019 :
    I agree. apply the glue with one of the brushes they provide. also, make sure you are buying from the seller "nutflim" I guess there are frauds trying to sell a knock off.
  3. Android450 Lollipop Jan 3, 2019
    Android450, Jan 3, 2019 :
    Can I apply this screen protector like how the instructions for the official screen protector say to? I like being able to use the included case as an alignment tool
  4. bpwest80 Jelly Bean Jan 3, 2019
    Yeah, the knockoff doesn't come with the glue so look for the Nut Film (Updated) listing.
  5. bpwest80 Jelly Bean Jan 3, 2019
    Here it is with no case on.
  6. bpwest80 Jelly Bean Jan 3, 2019
    I guess but I didn't.
    Android450 likes this.
  7. NMD2018 Honeycomb Jan 3, 2019
    bpwest80 likes this.
  8. bpwest80 Jelly Bean Jan 3, 2019
    Yeah it's a good one. Glue around the edges is still holding up on mine so far.
    NMD2018 likes this.
  9. bpwest80 Jelly Bean Jan 3, 2019
    I swear I've lost my mojo applying tempered glass. I seem to always get a spec or two of dust underneath. It's so frustrating. I used to to have an issue with dust or lint. I got the one on my 6T perfect but I tried 4 or 5 others that ended up not working due to not sticking to the edges but I got lint under them too. I Just applied two tempered glass for my daughter on her 8 Plus and iPad and I got two pieces of lint on the iPad and two specs of something on the 8 Plus. It probably won't bother her but I can't stand it. I keep trying though. I'll get my mojo back sooner or later.
  10. Android450 Lollipop Jan 3, 2019
    Got my screen protector this morning Installed smoothly had a slight bubble in the corner but it worked itself out in an hour Definitely loving it
    G_Andrew_DuLac_InWk and bpwest80 like this.
  11. bpwest80 Jelly Bean Jan 3, 2019
    Glad you like it. I like mine too. I'd hang onto that glue. It could come in handy in the future.
  12. Prateekjain2003 Froyo Jan 3, 2019
    Prateekjain2003, Jan 3, 2019 :
    If you remove the tempered glass do let us know if there was any ill effect of the glue on the screen..
  13. bpwest80 Jelly Bean Jan 3, 2019
    Will do. There won't be though. I wiped the excess glue off with a micro fiber cloth. All it would take would be a little bit of alcohol and you probably wouldn't even need that.
  14. felipemendes Jelly Bean Jan 11, 2019
    felipemendes, Jan 11, 2019 :
    Installed it too. Honestly, at first I thought it was social advertising. But it really works decently. The glue makes the whole difference. Without it, borders will not stick. When I applied the glue, there was a thin stripe of air between the glue and the line where the glass sticks to the screen. So one should apply the glue in only one direction so the air has where to escape. But after the glue goes where it should, it looks perfectly. I wiped excess glue with toilet paper and nothing else.
    But is not an installation for the fainted hearted.
    G_Andrew_DuLac_InWk likes this.
  15. felipemendes Jelly Bean Jan 14, 2019
    felipemendes, Jan 14, 2019 :
    After 2 days of use, I can say that optically this works fine. However fingerprint recognition is now atrocious. I had re-recorded my FPs with the new glass, but still horrible. Right thumb is decent at best (compared to the stock protector), but all other fingers are barely recognizable.
