5
Excessive battery drain om OnePlus 6
  1. ankijais
    Eclair Oct 6, 2018
    ankijais , Oct 6, 2018 :
    battery is getting drained at a faster rate and phone is heating up a lot. even after charging it and rebooting it, there is no change, its not like 5-2%, lost 10-20% within an hour without using anything...is it happening coz of new system update? please help, my phone is continuously hot, can't use it properly
  2. Q1533051386726
    Donut Oct 6, 2018
  3. ankijais
    Eclair Oct 6, 2018
  4. Q1533051386726
    Donut Oct 6, 2018
  5. Saiteja.Vaidya
    Eclair Oct 6, 2018
  6. ankijais
    Eclair Oct 6, 2018
    my brother took tht mobile out, m nt able to check, but i believe ots latest version with system software update that came in last week, coz we updates it three days back
  7. Q1533051386726
    Donut Oct 6, 2018
    Q1533051386726 , Oct 6, 2018 :
    I agree. lots of glitch. wish i had not pressed the update button
    F_Mehul_Patel_doJo likes this.
  8. Q1533051386726
    Donut Oct 6, 2018
    if its Pie then that makes sense cause its killing my battery too. about the heat tho, I cant say for sure. it depends on your usage
  9. ankijais
    Eclair Oct 6, 2018
    kept it in off mode for an hour, later on used it for WhatsApp, it was again draining battery n heating up,, is der a way to uninstall update or check battery temp
  10. jhona83
    Donut Oct 6, 2018
  11. ankijais
    Eclair Oct 6, 2018
    Deactivated User likes this.
  12. G_Ciprian_Mihai_CfCD
    Gingerbread Oct 6, 2018
    G_Ciprian_Mihai_CfCD , Oct 6, 2018 :
    It's not Android Pie. It's related to some apps that are bad designed. Mine is updated to pie and works well. And I use it intensively for everything except games. I am not a gamer. Should try to uninstall some apps that might cause problems and see if there is any change.
  13. Dickta
    Froyo Oct 7, 2018
    Dickta , Oct 7, 2018 :
    No it's not pie or oreo not even any app. I experiencing with my op6 and I found the trick. when my phone is on 4g/lte the battery drainage is huge. 15-20% overnight. but if I turn this network from 4g to 2g it's only 3-4%. That's a huge difference. Something in the modem is draining the battery. under Oreo the battery stats showed that under 4g node the phone constantly switching between 4g frequencies and that is what drain excessively the battery. Maybe the have to modify the system code to a longer frequency switching periods to avoid the drainage. with my op5t the periods are way soo longer and that's why the standby consumption is better in op5t on 4g also. please OnePlus software developer team solve this issue! At this state, the op5t is a way better phone than the op6. Do something please!
    Deactivated User and ankijais like this.
  14. Q1533051386726
    Donut Oct 7, 2018
    Q1533051386726 , Oct 7, 2018 :
    well whatever the problem is, im sure we all agree on wanting the pie battery performance to be better or at least the same when on oreo.
    ankijais likes this.
  15. ankijais
    Eclair Oct 7, 2018
    ankijais , Oct 7, 2018 :
    i tried uninstalling some excessive battery draining apps, nd dark mode, coz of that battery drain is reduced.
    I have op5t too, will check how 2g mode helps in night
    Q1533051386726 likes this.
  16. G_Praveen_Kumar_G_tNbt
    Cupcake Oct 7, 2018
  17. Dha_nush
    Cupcake Oct 7, 2018
    Dha_nush , Oct 7, 2018 :
    I recently buyed OnePlus 6 all is working fine but after upgrading to pie it's started to drain battery slightly can I know why??
  18. Shiv4mv10
    Cupcake Oct 7, 2018
  19. Madhavg4
    Cupcake Oct 7, 2018
    Santoshtheone likes this.
  20. jhona83
    Donut Oct 24, 2018
    jhona83 , Oct 24, 2018 :
    Recently l install the beta 4 of oxygen OS and the issue with the battery its fix! Now my battery it's working fine.
