Exchange Service Battery drain
  1. erwann.jeanneau
    Eclair Dec 18, 2015
    erwann.jeanneau , Dec 18, 2015 :
    Hi,
    It seems that the exchange services (needed for my pro mail address) results in extreme battery drain. My battery would drop to 0% within a day with very light usage (few phone calls, ~30 mn of videos, few SMS and mails). My SOT is 2 hrs maximum (usually more like 1-1h30 hrs).
    Anyone facing this issue ?
    I also noticed that there is two versions of exchange services that are installed (6.5 and 5.1.1). Is this normal ?
    any kind of help would be apppraciated
    N1549420892336 likes this.
  2. Helbro
    Ice Cream Sandwich Dec 18, 2015
  3. erwann.jeanneau
    Eclair Dec 18, 2015
    That's one solution but I did not encounter this issue with my previous phones (nexus 4, LG Bello) so there might be a bug somewhere.
  4. Goggeboy
    Honeycomb Dec 18, 2015
    Goggeboy , Dec 18, 2015 :
    No need to root, just install MailWise app. You can configure it, like sync every 30 min or 1 hour, saves your battery
  5. erwann.jeanneau
    Eclair Dec 18, 2015
    thanks but I need push mail, calendar and contact sync. I would like to keep my gmail and exchange accounts in gmail app like I used to do before.
  6. ehsan warasi
    Cupcake Dec 20, 2015
  7. Axevictim
    Gingerbread Dec 20, 2015
    Axevictim , Dec 20, 2015 :
    How do you do that on lollipop as all i can see is sync on/off ?
