Extended Battery Optimization Bug
  1. Dimon2011 Eclair Sep 4, 2018
    Dimon2011, Sep 4, 2018 :
    Activate Extended Battery Optimization and then for example disable on App Base, to not optimize the background activity (example What's App). The App does not get notifications and after some time in the battery settings, the app switches automate to "optimize" background activity. The only solution is to disable the extended battery optimizations...
  2. Tevito Gingerbread Sep 6, 2018
    Tevito, Sep 6, 2018 :
    I'm having the same problem. Wasn't there before..
    I'm running the Open beta 15 on my OnePlus 5T.
