Battery/Charging External. Battery
  1. natruim
    Froyo May 18, 2017
    natruim , May 18, 2017 :
    Hi
    I need an external battery for my OnePlus 2. One that can charge fast and till 100 % would be the best!
    Any advice? Thanks
  2. stijnvankampen
    Cupcake May 18, 2017
    Maurits Fiems likes this.
  3. natruim
    Froyo May 18, 2017
  4. natruim
    Froyo May 18, 2017
    Is an external battery with the "Quick Charge" option would suit to the Oneplus 2?
  5. baz418
    Gingerbread May 18, 2017
    baz418 , May 18, 2017 :
    The best option is using the oneplus powerbank
    Don't risk to use a battery pack with Quick charge option. use a decent one ( I'd recommend Anker or Zendure A2)
    NEVER BUY CHEAP POWERBANKS AS THEY CAN DAMAGE YOUR PHONE
    The risk of using a quick charge battery pack or charger is like 0.00001% getting your phone damaged as electronics inside the phone regulate the input current and voltage to the phone, but hey its electronics and you never know when it will go crazy. Keep that in mind and wish you happy charging.
    stijnvankampen and natruim like this.
  6. natruim
    Froyo May 18, 2017
    Thank you
    I couldn't find anywhere the OnePlus PowerBank so I might order an Anker one.
    baz418 likes this.
  7. projuker99
    Donut May 18, 2017
    natruim likes this.
  8. natruim
    Froyo May 18, 2017
  9. M4Master
    Honeycomb May 19, 2017
    M4Master , May 19, 2017 :
    That depends on your country...
    Buy Mi Powerbank from their official site...
    they are pretty good...
    If you are from India, search on Flipkart, they were selling 11000mAh Powerbank just for ₹700 or something
  10. Maurits Fiems
    Donut May 19, 2017
    Maurits Fiems , May 19, 2017 :
    I have two Xtorm powerbanks, they allow dash charging. OP does have great powerbanks. just make sure you don't buy those cheap unbranded ones.
