Sound Extremely low volume on BT
  1. Luismi Calleja
    Cupcake Nov 4, 2020
    Luismi Calleja , Nov 4, 2020 :
    Hi
    I have noticed that the volume of bluetooth audio both in headphones and in two different cars is really low. someone else with this problem?
  2. Dinesh_Rathore
    Honeycomb Nov 4, 2020
  3. SultanaDaaku
    Honeycomb Nov 5, 2020
  4. Bittoo06
    Jelly Bean Nov 5, 2020
    Bittoo06 , Nov 5, 2020 :
    Check the battery of the headsets. Check the BT codec in developer options. The issue might get solved by changing the codec in Developer settings. Some sites or videos have low sound than others. So it might be an issue as well.
  5. #5
  6. Luismi Calleja
    Cupcake Nov 26, 2020
    Luismi Calleja , Nov 26, 2020 :
    Hi, I've compared the 8T against a iP12 and a OP6T.
    The difference is INSANE.
    In a dedicated BT equalizer the 8T can't show a single dB meter...
    This is ridiculous
  7. Xpress0
    Gingerbread Nov 26, 2020
  8. eve_ouyang
    Donut Nov 27, 2020
  9. #9
  10. B1616586964851
    Cupcake Mar 24, 2021
    B1616586964851 , Mar 24, 2021 :
    same here ,so no solution? i reseted BT ,cleared caches everything now BT cant even find earphones
  11. #11
  12. IlWizardxp
    Froyo Apr 26, 2021
  13. #13
