Extremely poor battery on brand new phone!
  1. jmthakur
    Eclair Jan 29, 2015
  2. jmthakur
    Eclair Jan 29, 2015
    jmthakur , Jan 29, 2015 :
    @vigneshvar1 I did not get you. I have already done a factory reset a few hours back today as can be seen from my comment above. Will it help doing it again once it has not worked first time in same day?
  3. jmthakur
    Eclair Jan 29, 2015
    This is screen shot a few minutes back. I had charged it to 100% at 8pm. In about 3.5 hours it is down to 82% in airplane mode. Only use made was to delete many apps.
    Bit worried now. Have browsed more posts on this forum. Have come to like this mobile. Hope I don't have to return it and remain with my Note. :(
  4. sarcha
    Honeycomb Jan 29, 2015
    sarcha , Jan 29, 2015 :
    I liked ur attitude buddy.. And really appreciate it
    cabhay likes this.
  5. sumchamp
    Froyo Jan 29, 2015
    sumchamp , Jan 29, 2015 :
    This is nothing but wakelocks which are eating your battery. Don't worry about it. Install greenify and greenify some apps to disable their wakelock(push notifications). Trust me your battery will improve immensely.
    jmthakur likes this.
  6. jmthakur
    Eclair Jan 29, 2015
    @sumchamp. Already installed greenock and greenified almost all apps except those that I can't or are needed. Have disabled by denying wake up etc Google play services also. Stopped almost all sync service desk like mail etc.
    No change.
  7. sumchamp
    Froyo Jan 29, 2015
  8. sarcha
    Honeycomb Jan 30, 2015
    sarcha , Jan 30, 2015 :
    Return the phone and order a new one
  9. jmthakur
    Eclair Jan 30, 2015
    jmthakur , Jan 30, 2015 :
    Hi! Here's the update of overnight change. I charged the mobile at 8pm yesterday to 100% and kept it on airplane mode overnight. Early morning, when I checked, battery was down to 82%. However, it gave some error message in very light/faded almost invisible notification and when I pressed an icon on notification, the mobile went on an endless loop. I switched it off by keeping power button pressed. And then tried to switch it on. Again it went in same endless loop (the oneplus red circle consisting of rectangles kept going round and round apparently rebooting but really not). Finally, I switched it off again and then did a hard reset (power+volume down and then selected "reset").
    On switching it on I ensured that after login it did not automatically download all my apps (by inactivating automatic download in Google Play). Hence, only the stock apps that came with mobile are there. At that time - 6.25am - battery was 68%. Now, about 3 hours later, it is 67%! Is this good news or it is too premature to conclude?
    I plan to download a very selected few apps only - the ones I really need - one at a time. e.g., Swiftkey first, then Simplenote, then esexplorer. I don't plan to use talk/sms services for at least a week.
    So should I wait for a day or two, and try it out? Or do I give it up and return? I am not sure if I return, I will get a replacement - and maybe I will have to go back in queue for an invite. But for this issue, I have come to like the mobile. I have a few more days within which I can return to Amazon.in.
    Thanks for support till now and will appreciate suggestions. Thanks!!
    zeus.01.01.01.01 likes this.
  10. gamejump
    Froyo Jan 30, 2015
    gamejump , Jan 30, 2015 :
    amazon dont offer replacement they offer refund
    looks like the phone having some problem
  11. jmthakur
    Eclair Jan 30, 2015
  12. darkclouds
    Gingerbread Jan 30, 2015
    darkclouds , Jan 30, 2015 :
    Disable sync and location sharing. Switch off wifi and data. This should give you a very low stand by drain, provided you don't have any messenger apps installed. May not be a good idea to return till the battery issue is confirmed.
  13. mayanks
    Jelly Bean Jan 30, 2015
    mayanks , Jan 30, 2015 :
    Seems like hard reset solved the problem..
  14. jmthakur
    Eclair Jan 30, 2015
    @darkclouds :- I have disabled sync, and wifi/data and even mobile services are off. I have not installed any messenger apps.
    How do I disable "location sharing"? I have set "location" at off. Do I need to do anything further.
    Appreciate your suggestion re not to return till battery issue is resolved. Will wait for a couple of days at least and observe. Thanks!
  15. jmthakur
    Eclair Jan 30, 2015
  16. darkclouds
    location 'off' is just fine. You can try installing betterbatterystats to find out about wakelocks. After installing enable 'Active monitoring' and you can see after each screen off how much sleep/wake time spent. Ideally close to 100% sleep time is preferred, but varies heavily depends on apps.
  17. cabhay
    KitKat Jan 30, 2015
    cabhay , Jan 30, 2015 :
    Keep in mind your amazon return date. I think your problem is solved but test your mobile as much as possible before that date. I have exactly 100 icons in app drawer and battery drain in normal
  18. jmthakur
    Eclair Jan 30, 2015
    yes, @cabhay - will do just that. Over weekend particularly will add more apps and then increase browsing, etc. I have at least a week before I take final decision re keep/return. Thanks.
    #38
    cabhay likes this.
  19. sumchamp
    Froyo Jan 30, 2015
    sumchamp , Jan 30, 2015 :
    I guess your issue has been fixed. Use it normally and monitor battery for few days.
    #39
  20. jmthakur
    Eclair Jan 30, 2015
    @sumchamp - looks like it. I have updated all existing apps - all google stock ones - and charging mobile back to 100%. Will report tomorrow after keeping mobile on airplane mode overnight.
    Thanks!!
    #40
    sumchamp likes this.
