face detection is not working in OP6
  1. LuxmanG
    Donut Jun 30, 2018
    LuxmanG , Jun 30, 2018 :
    Hi guys,
    face detection is not working in my new oneplus6 phone. please let me know what's the issue?
    thanks in advance.
  2. F_Martin_Jakobsen_eRgY
    Ice Cream Sandwich Jul 1, 2018
    F_Martin_Jakobsen_eRgY , Jul 1, 2018 :
    Get a new face. :)
  3. adrnjgr
    The Lab - OnePlus 6 Reviewer Jul 1, 2018
    adrnjgr , Jul 1, 2018 :
    You'll have to be more specific. Do you have the option turned on and it gives some sort of error?
  4. Android-Andi
    Jelly Bean Jul 1, 2018
    Android-Andi , Jul 1, 2018 :
    maybe delete the face and readd it. first time I added my face in not best light conditions, had to readd it to get it working better.
    Davide Swarup likes this.
  5. Davide Swarup
    Cupcake Jul 1, 2018
  6. G_Akhil_Sojan_zChE
    Cupcake Jul 1, 2018
    G_Akhil_Sojan_zChE , Jul 1, 2018 :
    Even I faced the same issue. Some sort of hangs take place in the add face button. I had to Factory reset my phone. Maybe it's the issue of the new update. Please fix this
  7. honeytoor
    Cupcake Jul 1, 2018
  8. G_Akhil_Sojan_zChE
    Cupcake Jul 1, 2018
    Will that affect the Face Unlock???
  9. dannyjohn3003
    Donut Jul 1, 2018
    dannyjohn3003 , Jul 1, 2018 :
    Mine is working perfectly. The only thing I don't like about it is that you have to press the power button. It should just automatically unlock when detecting your face like the Huawei p20 series.
    LuxmanG likes this.
  10. honeytoor
    Cupcake Jul 1, 2018
    honeytoor , Jul 1, 2018 :
    Will make face detection slow.
    I had a tampered glass installed and it used to cover the front camera lens and i saw that the face detection started taking some time than usual. And there was dirt underneath the tampered glass which covered the front camera. So i removed it. Now its fine.
    G_Akhil_Sojan_zChE likes this.
  11. Atulit1
    Honeycomb Jul 1, 2018
    Atulit1 , Jul 1, 2018 :
    obviously. front camera is used for face unlock
  12. Dj_chemie
    Nikhil Seenivas likes this.
  13. Dj_chemie
    Dj_chemie , Jul 1, 2018 :
    it would drain battery because the camera would have to constantly look for your face..
  14. Fernando_G_Joao
    Gingerbread Jul 1, 2018
    Fernando_G_Joao , Jul 1, 2018 :
    You can turn on double tap to wake and it will unlock very fast...
    dannyjohn3003 and Davide Swarup like this.
  15. LuxmanG
    Donut Jul 8, 2018
  16. Graff Nicolas
    Cupcake Jul 8, 2018
  17. LuxmanG
    Donut Jul 8, 2018
    LuxmanG , Jul 8, 2018 :
    no it's not..
  18. Graff Nicolas
    Cupcake Jul 8, 2018
    Graff Nicolas , Jul 8, 2018 :
    i have the op6 ans he don't unlock on my profile juste at the front face, if that gay put his finger at the fingerprint sensor it's par that open the phone.
  19. Graff Nicolas
    Cupcake Jul 8, 2018
    you can make as you whant in a vidéo are you sure the man as activate the face unlock ? no !
