Face recogniton not working!
  1. ruel61
    Cupcake Jan 10, 2018
    ruel61 , Jan 10, 2018 :
    I tired setting up the smartlock but after that,when i tried it,it doesnt work.heeelp
  2. G_Hemant_Kumar_nZOi
  3. ruel61
    I tried.i did that thing.but when testing it out.its not recognizing
  4. Solomonxx
    Froyo Jan 10, 2018
    Solomonxx , Jan 10, 2018 :
    you need to press the power button on the side to wake the display and then swipe up after it unlocks, and if it's not working, try to remove your face and add it again.
    ruel61 likes this.
  5. G_Hemant_Kumar_nZOi
    G_Hemant_Kumar_nZOi , Jan 10, 2018 :
    ruel61
    I tried.i did that thing.but when testing it out.its not recognizing​
    i was also faced same issue..... It will unlocked once you press power button it detect your face automatically and now you have to just simply manually swipe the Lock screen upward to unlock it....try it I have also unlocked it.....it definitely unlock your phone......
  6. ruel61
    Its now working.thank you so much.so you always have to press the power button first and swipe it up inorder to unlock.i've always thought that even if the display is off,you just look at the cam and it will unlock.what a bummer.
  7. Deactivated User
    Jan 10, 2018
