face unlock dash charge
  1. bvotje
    Froyo Feb 11, 2018
    bvotje , Feb 11, 2018 :
    So when face unlock is on dash charge is not working on 5.03. Anyone with the same problem?
  2. kumaryashwin
    Jelly Bean Feb 11, 2018
  3. Y1511783653708
    Gingerbread Feb 11, 2018
  4. Triple_A
    Honeycomb Feb 12, 2018
    Triple_A , Feb 12, 2018 :
    The issue is not with face unlock. it's probably with ur charger. make sure that there is no dust in either of the connections (usb-phone & usb-power brick). If everything is clean get ur charger checked out.
    Make sure u use all original accessories.
  5. Bjmohanty
    Donut Feb 12, 2018
    Bjmohanty , Feb 12, 2018 :
    I think it's only text " Dash charging" does not appear. As at same place "no face detected tap here to try again" displayed. To ensure dash charging use ampere app, blue led and lightning symbole are also sign of dash charging working properly.
  6. bvotje
    Froyo Feb 18, 2018
    bvotje , Feb 18, 2018 :
    yes it is. when I disable face unlock it works fine. so I will not use face unlock any more
  7. BobbyV8_
    The Showcase Reviewer Feb 18, 2018
  8. X1516095264744
    Cupcake Feb 18, 2018
