19
Facebook App not working with Oxygen OS 2.1 (Possible workaround included)
Thread Status:
Not open for further replies.
  1. mykrobiote
    Froyo Oct 16, 2015
    mykrobiote , Oct 16, 2015 :
    O am having the same problem. As workaround I'm using the app metal. But I still prefer the official app, so waiting that the issue is solved
  2. Ganesh L
    Froyo Oct 16, 2015
  3. Dishlexic
    Froyo Oct 16, 2015
  4. mykrobiote
    Froyo Oct 16, 2015
  5. Shahfaisalkhn
    Gingerbread Oct 18, 2015
    Shahfaisalkhn , Oct 18, 2015 :
    Thanks Bro got it all sorted out in update
  6. Shahfaisalkhn
    New update fix the issue
  7. vijaywidluv
    Ice Cream Sandwich Oct 18, 2015
    vijaywidluv , Oct 18, 2015 :
    Am glad it worked.. Enjoy
  8. Sandy00H
    Cupcake Nov 30, 2015
  9. justinmraj
    justinmraj , Nov 30, 2015 :
    I also upgraded my OP2 to Oxygen 2.1.2.
    Its hangs when connecting to a 4g Hotspot.
  10. APAPEK
    Cupcake Dec 31, 2015
    APAPEK , Dec 31, 2015 :
    Found out that Facebook and Instagram crashed on my OP2 because off its limited acces to places. After changing this under Settings -> App permissions everything works great.
  11. charanchakravarthi
    Honeycomb Dec 31, 2015
    charanchakravarthi , Dec 31, 2015 :
    You are seeing app crashes on 2.2.0??
  12. APAPEK
    Yes!
  13. charanchakravarthi
    I haven't seen such a problem on the 2.2.0. Could you brief about the environment and specifics??
  14. ANOOPMOHAN
    Froyo Jan 15, 2016
  15. charanchakravarthi
    Honeycomb Jan 15, 2016
  16. ANOOPMOHAN
    Froyo Jan 20, 2016
    ANOOPMOHAN , Jan 20, 2016 :
    Now it's working after next updation...
  17. bgregster
    Cupcake May 25, 2016
    bgregster , May 25, 2016 :
    I have this problem and appreciate the workarounds (I'm using the website shortcut instead of back-versioning the app), but really can't understand why Oxygen is not compatible with the Facebook App of all apps - it is after all OK on all other android phones!
  18. B1567493352992
    Cupcake Sep 3, 2019
