[Submitted] Facebook apps is causing battery drain while using the app
  1. P1618474599186
    Cupcake Apr 15, 2021
    P1618474599186 , Apr 15, 2021 :
    My phone battery is draining so fast and the phone get so hot while using the facebook app. It is happening only at the time of using the app.
    Vala100 likes this.
  2. Suhas Klkrn555
    OnePlus Bug Hunter Staff Member Apr 15, 2021
    Suhas Klkrn555 , Apr 15, 2021 :
    We would like to check this further and have got in touch with you via personal conversation for more details.
    Please requesting you to respond to us at the earliest.
    Thanks & Regards,
    Suhas.
  3. P1618474599186
  4. Suhas Klkrn555
    OnePlus Bug Hunter Staff Member Apr 21, 2021
    Suhas Klkrn555 , Apr 21, 2021 :
    We appreciate your efforts to get the required information, Not to worry, our dev team is already working on this and will make sure to get this sorted at the earliest.
    Thanks & Regards,
    Suhas.
  5. karim.Fadel
    Gingerbread Apr 23, 2021
    karim.Fadel , Apr 23, 2021 :
    I have the same issue did they find any solution for that it's the Facebook drain battery and my device OnePlus 7 pro get hot
  6. Meister1977
    Gingerbread Jun 10, 2021
    Meister1977 , Jun 10, 2021 :
    I have the same issue.
    Few minutes can drain 10-15%
    And it keep running in the backgroud, but I set up to optimize the app in the settings/battery section.
  7. P1618474599186
    Cupcake Jul 4, 2021
  8. F_Dennis_Jonathan_Trajan
    Cupcake Jul 15, 2021
  9. Vala100
    Cupcake Nov 17, 2021
    Vala100 , Nov 17, 2021 :
    Same issue here few month already, OnePlus 7 Pro GM1913, Oxygen OS 11.0.4.1 GM21BA.
    Facebook App drains Battery like crazy 30% hour if in use + The phone gets extremely hot !!, 10% drain if works in background.
    App is Optimized in settings.
    Have no idea what to do now.
    Problem started since the last 2 system updates, every 2 minutes i get the system message of "Facebook App" is draining your battery.
    Please make a fix
