Facing a strange audio problem when using wired earphones via OnePlus Nord
  1. HarichandHarsha
    Cupcake Sep 17, 2021
    HarichandHarsha , via OnePlus Nord , Sep 17, 2021 :
    While using a wired earphones, the stereo separation is totally wrong. In my case, I'm hearing the vocal on the right ear and other partes of the sound on the left. This is very annoying while watching video and gaming on the device. Is there any way to fix this temporarily/permanently?
  2. HoLeetihs
    Ice Cream Sandwich Sep 17, 2021
  3. HarichandHarsha
  4. HarichandHarsha
  5. HarichandHarsha
  6. HarichandHarsha
  7. HoLeetihs
    HoLeetihs , via OnePlus Nord , Sep 17, 2021 :
    Yes, it seems this has been common issue with some OnePlus devices so I don't think that problem is in your usb adapter.
    I suggest to be in contact with OnePlus support.
    If the earphones you have are cheap one and you have soldering skills one option is to try to swap the earpieces. However it won't be easy so I wouldn't try this method for the expensive ones...
    HarichandHarsha likes this.
  8. Pinku Reddy
    Gingerbread Sep 17, 2021
  9. HarichandHarsha
    Cupcake Sep 18, 2021
    HarichandHarsha , via OnePlus Nord , Sep 18, 2021 :
    No it is not an official one. But when I went thru forums I could see it is a software issue. So I'm in search of a way to fix it atleast temporarily and wait for the official fix from #Oneplus
