3
[Submitted] Facing battery drain in OnePlus 8t
  1. Sidharth.v
    Eclair Dec 30, 2020
    Sidharth.v , Dec 30, 2020 :
    The new OnePlus 8t battery draining so fast and when it is idle the charge drains
    I am so sad of this battery draining issue I even use it in 60hz but then also draining so fast
  2. ashugmangu
    Eclair Feb 1, 2021
    ashugmangu , via OnePlus 8T , Feb 1, 2021 :
    Yes you are right , brand new flagship Cellphone 4500 mah and cost 700USD
    Why should we turn on battery saver!
    Company should come with some better updates.
    Should learn from Xiaomi and Huawei. How they make up to increase the battery usage time.
    H1610288991288 likes this.
  3. A1612087376160
    Cupcake Feb 2, 2021
  4. Sidharth.v
    Eclair Feb 2, 2021
    Sidharth.v , via OnePlus 8T , Feb 2, 2021 :
    Yes of course
  5. raghavsoni_16
    Donut Feb 2, 2021
  6. AaronCJ
    Cupcake Feb 5, 2021
    Sidharth.v and Q1608462207911 like this.
  7. MrKi11er
    Cupcake Feb 10, 2021
    MrKi11er , via OnePlus 8T , Feb 10, 2021 :
    Which oxygen version you are using ?
    Sidharth.v likes this.
  8. jefin , via OnePlus 8T Aquamarine Green , Feb 10, 2021 :
    Yeah bro...I used to get 8 hours screen on time...But after the latest update which I received 2 days ago I'm only getting 6hr SOT on regular use... without gaming...He'll, I shouldn't have updated
  9. #9
  10. Sidharth.v
    Eclair May 8, 2021
    Sidharth.v , via OnePlus 8T , May 8, 2021 :
    Yes after the update
