2
facing heating problem while charging via OnePlus 6T Midnight Black
  1. imvikram28 , via OnePlus 6T Midnight Black , Apr 10, 2021 :
    hi team this is to highlight that i am facing heating issue while charging the mobile m using original charger and cable and not even using mobile while charging..
    facing this issue after last update please look into this.
    iamrj and sajid06 like this.
  2. Vivek2989
    Gingerbread Apr 10, 2021
    sajid06 likes this.
  3. ItsRavi25
    Jelly Bean Apr 11, 2021
    ItsRavi25 , via OnePlus 6T , Apr 11, 2021 :
    For battery draining and heating issue try this.
    You can calibrate to enhance your battery life
    For battery draining you should follow this to calibrate..
    Goto settings >App and notifications>Click on three dot in right corner>Reset app preference.
    To Optimize the phone, clear your recent apps, also set 3rd party apps to Optimize in Settings Battery, only leave the ones you need run in the background or to notify you such as messages, email, Google Services, oneplus etc on Intelligent control.
    For information go through this thread.
    https://forums.oneplus.com/threads/unified-op6t-battery-and-heating-thread.952987/
    Battery analysis and battery drain trouble solving ( @Swejuggalo )
    https://forums.oneplus.com/threads/battery-analysis-and-battery-drain-trouble-solving.1413430/
    Battery Facts
    https://forums.oneplus.com/threads/battery-facts.995140/
    Guide to lower Battery Drain.
    Thanks to @Caomhin 😇...
    Caoimhín likes this.
