Facing issue with Proximity Sensor
  1. M1564370560898
    Donut Nov 7, 2019
    M1564370560898 , Nov 7, 2019 :
    I'm using one plus 7 . after updated to Android 10 proximity sensor not working. please fix this issue asap
  2. NikhilParashar
    Eclair Nov 7, 2019
    NikhilParashar , Nov 7, 2019 :
    In my opinion , the proximity sensor in phones with waterdrop notch is broken
    OnePlus uses some software magic to turn the screen off while on call.
    installing 'sensor test' app from play store , it will detect proximity sensor only if you raise the phone to your ear.
  3. MarkDAust
    Cupcake Jan 18, 2020
    MarkDAust , Jan 18, 2020 :
    Cannot get the senor to work.
    Installed Sensor Test app and sensor does work.
    Installed AutiScreenOnOff app - works fine.
