Facing Issues after Oxygen OS 4.1.5
  1. ayushsinghp
    Froyo Jun 7, 2017
    ayushsinghp , Jun 7, 2017 :
    After updating to oxygen os 4.1.5,actually the whatsapp app loads slower than ever and after unlocking the app using fingerprint it takes a hell lot of time to open up and also for some other apps too. Could someone please tell me why this might have happened.
    Ajdi likes this.
  2. Bartnl
    Lollipop Jun 7, 2017
    Bartnl , Jun 7, 2017 :
    Start up in recovery, empty cache and Dalvik and problems solved.
    You could have found the solution easily by using the search function of the forum.
  3. ayushsinghp
    Froyo Jun 7, 2017
  4. ayushsinghp
    Froyo Jun 7, 2017
    No i am not able to find any search result similar to it
  5. Yash Bhardwaj
    Jelly Bean Jun 7, 2017
    F_Diganta_Koner_WIXu likes this.
  6. Bartnl
    start up in recovery and you will see that you can empty the cache and dalvik (also a sort of cache)
  7. Bartnl
  8. ayushsinghp
    Froyo Jun 7, 2017
  9. SJBoss
  10. you_weee
    Gingerbread Jun 7, 2017
  11. Bartnl
  12. ayushsinghp
    Froyo Jun 7, 2017
    Thanks... It helped
  13. you_weee
  14. at0mixX
  15. sapnikos
    Eclair Jun 7, 2017
    sapnikos , Jun 7, 2017 :
    mine was also lagging the first few minutes after the upgrade. I did another restart and the everything working perfect
  16. sapnikos
    Eclair Jun 7, 2017
  17. sapnikos
    Eclair Jun 7, 2017
    You can download the opera app. Change your region in Canada and then the update will show up immediately
  18. Android450
    Marshmallow Jun 7, 2017
    Yash Bhardwaj likes this.
  19. pinakidh
    Cupcake Jun 7, 2017
  20. Android450
    Android450 , Jun 7, 2017 :
    It's rolling out
