Facing issues with front camera via OnePlus 6
  1. Deepshikha_K_K
    Cupcake Oct 21, 2020
    Deepshikha_K_K , via OnePlus 6 , Oct 21, 2020 :
    I cleared the cache and then restarted , after that , I switch to the front camera , It's showing complete black out , And the phone is hanged.
    I am facing this issue after the last software update.
    please help
  2. pablofg1978
    Nougat Head Moderator Oct 21, 2020
    pablofg1978 , Oct 21, 2020 :
    Try to clean the camera app cache and storage
  3. Deepshikha_K_K
  4. Deepshikha_K_K
  5. BeingIncog
    Nougat Oct 21, 2020
    BeingIncog , Oct 21, 2020 :
    did you try to install the version for OOS 11 or something?
  6. Deepshikha_K_K
  7. Deepshikha_K_K
  8. BeingIncog
    Nougat Oct 21, 2020
    i meant to ask if installed apk from apkmirror?
  9. Deepshikha_K_K
  10. mohd_areeb
    Honeycomb Oct 22, 2020
    mohd_areeb , via OnePlus 6 , Oct 22, 2020 :
    Go to settings>Apps>all apps >tap on the three dots above on the right side>tap on reset app preferences.
    Then clear data & cache of camera app and force stop it, remove all recent apps reboot phone and then try opening the camera.
    If the problem still exists then backup your data and do a clean factory reset
