Facing network issue in one plus 7 pro via OnePlus 7 Pro
  1. vinodkumar1248
    Cupcake Oct 16, 2020
    vinodkumar1248 , via OnePlus 7 Pro , Oct 16, 2020 :
    Hi Team
    Recently I'm facing signal issue in my one plus 7 Pro mobile like every time after talking to some one in phone,mobile signal for both sims are going off and coming.
    Could some one please help on this.
  2. dinbandhukumar
    Ice Cream Sandwich Oct 16, 2020
    dinbandhukumar , via OnePlus 7 Pro Mirror Gray , Oct 16, 2020 :
    have you checked same sim in other device , whether you are getting proper network in other device.
    try to reset network from settings- system- reset option select 1option and try to reset and check it is working fine or not.
  3. vinodkumar1248
    Cupcake Oct 20, 2020
  4. Artemus.
    Community Hero 2020 Oct 20, 2020
    Artemus. , Oct 20, 2020 :
    You never mentioned what network you're on.
  5. vinodkumar1248
    Cupcake Oct 21, 2020
  6. G1562517220309
    Cupcake Dec 18, 2020
    G1562517220309 , Dec 18, 2020 :
    Hi Team,
    I'm one plus 7 pro user, I'm using only single sim & after installing the recent updates I'm facing network issue, my mobile sim signal goes of very frequently like less than 5mins and would get back the signal only after mobile restart.
    multiple times mobile restart may downgrade the battery life.
    I'm very depressed because of this issue, I have also tried replacement of my simcard but it doesn't solve my problem yet. I am on Vodafone Idea network VI.
    request the team to provide the necessary help to fix this issue quickly.
    Thanks and Regards
    Ganesh C
  7. Artemus.
    Community Hero 2020 Dec 18, 2020
    Artemus. , Dec 18, 2020 :
    First, no team here. Second, you need to mention which network carrier you're on.
  8. G1562517220309
  9. G1562517220309
    same in my case too..
