facing problem in opening PUBG mobile
  1. M1539310531414
    Cupcake Sep 16, 2019
    Punit G likes this.
  2. B_Wrath
    Marshmallow Sep 16, 2019
    Kytharsis likes this.
  3. itsFreelancer
    Gingerbread Sep 16, 2019
  4. M1539310531414
    Cupcake Sep 20, 2019
    M1539310531414 , Sep 20, 2019 :
    if it's not oneplus problem then what about other apps ?...i am facing the same issue with other apps also
  5. M1539310531414
  6. B_Wrath
    Marshmallow Sep 20, 2019
    B_Wrath , Sep 20, 2019 :
    You didn't specify that before, did you? Are we supposed to read your mind?
    If you face problems with multiple apps, back up your important data, do a factory reset and setup as new phone. Don't setup from Google backup.
    drl431 likes this.
  7. M1539310531414
    Cupcake Sep 21, 2019
    M1539310531414 , Sep 21, 2019 :
    yes i already did it...i did factory reset, and made it as a new device but my issue is not resolved... remember it's happening in some times only..
  8. sagarshenoy
    Gingerbread Sep 21, 2019
    sagarshenoy , Sep 21, 2019 :
    U are running on the official public build or any beta version??
  9. M1539310531414
    i am using official public build OxygenOs version
    9.0.8
  10. B1569037534542
    B1569037534542 , Sep 21, 2019 :
    go near by service center, may be there is problem with your phone , i didn't see this problem in any 1+ device
  11. sagarshenoy
    I had this problem when I had bought my oneplus 6.
    I bought it as soon as it was released, so in the first 2 weeks or so I had such bugs and issues.
    But all of them got solved with updates.
  12. Nichrome
    Honeycomb Sep 22, 2019
    Nichrome , Sep 22, 2019 :
    I was facing this issue when I disabled Chrome.. reenabling it fixed everything.
  13. M1539310531414
    Cupcake Sep 22, 2019
    M1539310531414 , Sep 22, 2019 :
    does beta verion can solve this issue ? if beta verion can solve this isuue means i will switch to beta version...please sujjest me
