Facing problem picking up calls when phone is locked
  1. anmolkhanna11
    Gingerbread May 7, 2017
    anmolkhanna11 , May 7, 2017 :
    Is anyone else facing problem to receive calls when the phone is locked and you have 4 5 notification on the lock screen ? First of all you have to search which is the call Notification and you have to unlock your phone . They should really work on it and change the way you receive your calls when the phone is locked .
  2. fonzobreaker
    Ice Cream Sandwich May 7, 2017
    fonzobreaker , May 7, 2017 :
    yup if you casually dismiss the call than you have to search it tap on it to bring back the calling interface ...kinda boring sometimes
  3. F_Abhivendra_Singh_YUtx
    Cupcake May 7, 2017
  4. G_Angelo_Cammarata_jmpz
    Eclair May 7, 2017
    G_Angelo_Cammarata_jmpz , May 7, 2017 :
    it happened once to me, though the most annoying dialer bug happened when the slider simply doesn't work and you can't pick up nor dismiss the call. (oh, in my case proximity sensor is still buggy)
    anmolkhanna11 likes this.
  5. anmolkhanna11
    Gingerbread May 8, 2017
    anmolkhanna11 , May 8, 2017 :
    yes that dialer bug happrned to me also.
  6. F_Ann_Francis_QNIf
    Cupcake May 8, 2017
