Facing Wifi issue via OnePlus 7T
  1. E1577462638175
    Cupcake Oct 16, 2021
    E1577462638175 , via OnePlus 7T , Oct 16, 2021 :
    From past 3-4 days I'm not able to use Wifi at all. I can use the same network in apple but not on my 7T. I'm not sure if it's because of an update which I did recently or clicked on some settings. Can anyone help me resolve this.
  2. Cervantes
    Moderator Moderator Oct 16, 2021
    Cervantes , Oct 16, 2021 :
    Hello
    Please, Use the search engine before opening a new thread: Search
    the forum: Introduce Yourself, it is not to ask about a phone problem, thread moved to support
    Read the forum rules: Rules
    Caomhin likes this.
  3. Caomhin
    OnePlus 9 Series Expert Community Expert Oct 18, 2021
    Caomhin , via OnePlus 9 Pro , Oct 18, 2021 :
    Reset your Network adapters, see if that helps.
    Settings, System, Reset Options, Reset WiFi Mobile Bluetooth.
    Also try the following. If the option is available to you.
    Go to Settings, WiFi & Internet, WiFi, WiFi Preferences and disable Intelligently Select the best WiFi.
    Also check out additional possible solutions at the link below.
    How To Fix Common Wi-Fi Problems In Android
    https://www.techjunkie.com/fix-wi-fi-problem-android/
