139
[FAQ] All about OxygenOS – April 2020
  1. andysandy
    Eclair Apr 22, 2020
    andysandy , Apr 22, 2020 :
    Agree. When I hide the bottom bar the rotate button doesn't show. And when I un-hide it, it shows.
  2. mohakavasthy
    Froyo Apr 22, 2020
    mohakavasthy , via OnePlus 7T , Apr 22, 2020 :
    Even i had the sane problem. You can call the OnePlus customer care and set a booking of remote flashing. It will be normal after that and will get stable version after flashing.
  3. litri6350
    Donut Apr 22, 2020
  4. chetan_patel
    Eclair Apr 22, 2020
    chetan_patel , via OnePlus 7 , Apr 22, 2020 :
    after receiving 10.3.2 update OP7 heating issue is not solved and charging time is increased from 1hr 15min to 1hr45min(15% to 100%). no problem other than the above in my OP7.
  5. M1584622613670
    Cupcake Apr 22, 2020
  6. M1584622613670
    M1584622613670 , via OnePlus 7 Pro , Apr 22, 2020 :
    When is the next version coming for 7 pro Cuz while long pressing the home screen it takes 2-3sec for the bottom options to appear. This problem i have started to faceafter the April 2020 beta update
  7. Anish V.R
    Anish V.R , Apr 22, 2020 :
    the fingerprint sensor is not working well for OnePlus 7 & when I use override dark mode some apps like messenger cannot be used because the entire app becomes white .
  8. BMRP
    BMRP , Apr 22, 2020 :
    This last update turned my 7 pro into a heater, battery drainer and have slowed the charging time, turning the warp charge off.
    Please fix this asap guys.
    Thanks.
  9. Arko88
    Cupcake Apr 23, 2020
    Arko88 , Apr 23, 2020 :
    After the new release, my phone is restarting automatically. No idea how to get this sorted.
    Vibgor likes this.
  10. PramodKinge
    PramodKinge , Apr 23, 2020 :
    H1570774538843
    needed camee improvements in one.plus 6​
    Feels the same..Actually I found that the photos taken from OP6 having less sharpness and the colours are dull..please fix this..
  11. mnatalia.mendieta
    mnatalia.mendieta , Apr 23, 2020 :
    Since the last update, I have noticed that the WiFi connection switch on and off the whole time, at the beginning I thought it was because of the router, but it works normally in my laptop and iPad. This situation only happens in my cellphone and it is really annoying when I'm doing calls or have work meetings.
  12. G1587403885646
    Cupcake Apr 24, 2020
    G1587403885646 , via OnePlus 7T , Apr 24, 2020 :
    oneplus7t gyropscope is not working after the update , how many times I have to post this ! no response from the customer care service , OnePlus seems to have zero interest towards their users .
    H1542153384332 likes this.
  13. Imhidu
    Eclair Apr 24, 2020
    Imhidu , via OnePlus 7 , Apr 24, 2020 :
    After the new update.... can see barely
    something due to the colour change in the shelf section...pls find a solution soon..
    Sean Forde likes this.
  14. H1542153384332
    Gingerbread Apr 24, 2020
  15. K1559682341545
    Eclair Apr 24, 2020
    K1559682341545 , Apr 24, 2020 :
    first thing u should bring more finger print animation,more clock style we can do much more in lock screen,when we compare with miui lockscreen oxygen os stand far behind it
  16. D1587844550531
    Cupcake Apr 25, 2020
  17. D1587844550531
