59
[FAQ] OnePlus X
You still rocking the ol' Rosy?
  1. She ded.
    2 vote(s)
    40.0%
  2. No, I have a....
    0 vote(s)
    0.0%
  3. Sure do!
    3 vote(s)
    60.0%
  1. Mr. BG
    Welcoming Expert, Community Hero 2020 Community Expert Oct 13, 2016
    Mr. BG , Oct 13, 2016 :
    No Chromecast here, but I think if you search on it you might be able to find some answers, i remember reading about it but I'm at work right now so i can't help you find it.
  2. Mr. BG
    No spoonfeeding, indeed... ;)
  3. Snoopy 82
    Cupcake Oct 13, 2016
    Snoopy 82 , Oct 13, 2016 :
    Nobody with the problem of sharing pictures from Facebook App? I have done factory reset and flashed full rom...given all the permissions, uninstalled and reinstalled the App... :(
  4. andhreas
    andhreas , Oct 13, 2016 :
    BUG:
    Bought Oneplus X to my mother and she got it last week. She is using a prepaid SIM, with NO free data so after changing phone and install everything I turned Data traffic off. A couple of days later all her money was gone, because data is still Active even if it turned OFF. This is CRAZY, and a bug that cost users money!! I googled it and see that other have the same issue on other Oneplus phones but didnt find any solution to it.
    I installed OOS 3.1.3 and did a factory reset before setting up the phone.
    This needs to be fixed ASAP.
  5. arsovmar
    arsovmar , Oct 13, 2016 :
    HI ,
    Notifications are refreshed only when i turn on the screen, when it's in sleeping mode i don't receive any and even my email app push notifications is not working. Anyone has this issue?
  6. Anokhin77
    Froyo Oct 13, 2016
    Anokhin77 , Oct 13, 2016 :
    Mr. BG. Please answer regarding Google Play Service app.
    Did you turn off background data for this app in the data usage settings?
  7. Pijaam
    Pijaam , Oct 13, 2016 :
    After 3 instalations trying to fix OnePlus Launcher crashing...the problem continues!
  8. Kéno40
    Jelly Bean Oct 13, 2016
    Kéno40 , Oct 13, 2016 :
    I did and it clearly slow down the power use of this ap. But I think Gmail doesn't synchr as quicly and there should be some others "bad" consequences.
    Anokhin77 likes this.
  9. ElleZeta
    Donut Oct 13, 2016
    ElleZeta , Oct 13, 2016 :
    Go to security/device administrator and uncheck "android device manager". I solve the Google Play Services problem doing that. No more Wifi always on (it was even if I did the location/scanning trick), no more Play Services drains battery
    Mr. BG and Anokhin77 like this.
  10. Anokhin77
    Froyo Oct 13, 2016
    So what do you think why Google Play Services has not shown in Mr.BG's battery history? Did he turn it off (background data for this app) or not everybody have so huge Google Play Services battery usage?
  11. Anokhin77
    Froyo Oct 13, 2016
    Oh! Thank you. I did it right now! Hope it helps me as well! Thank you very much!
  12. ElleZeta
    Donut Oct 13, 2016
    You're welcome.
  13. Deactivated User
    Oct 13, 2016
  14. Mr. BG
    i did, i'm at work now, will add this to first post later.
  15. fabiolanzi
    Ice Cream Sandwich Oct 13, 2016
    fabiolanzi , Oct 13, 2016 :
    It happened to me too before the update, afterwards I switched off data on the provider side ( I do not know if you can do that with your provider) and have not tried yet with the 3.1.3.
  16. SarkasmoX
    SarkasmoX , Oct 13, 2016 :
    Sometimes, when accessing an app through its notification at the lockscreen, the screen stops to respond to the touches and I have to turn off and on the screen to be able to use it. (The offscreen buttons work during the screen issue)
  17. addi1000
    Eclair Oct 13, 2016
    Matthius__ likes this.
  18. Cosmin OP
    Froyo Oct 13, 2016
    Cosmin OP , Oct 13, 2016 :
    You can create a new APN with wrong/no connection details. After that, you can set it as active and you are done.
  19. DanCtoo
    Honeycomb Oct 13, 2016
    DanCtoo , Oct 13, 2016 :
    Next time please talk with your brain, not your stomach.
    Discussed before, sure, but still no easy solution, still a bug.
    I don't concider logging out everything from google and factory reset easy.
    "Most" is relative...and you don't even know this from a few forum posts.
    I wait for the next OS update, maybe the LED notification is fixed then...
  20. fabiolanzi
    Since it is not a bug it will not be
