185
FAQs for OxygenOS 11 Open Beta
  1. N1593679741757
    Eclair Sep 30, 2020
  2. V1571402110664
    Cupcake Sep 30, 2020
  3. thenmozhi123
  4. Naveen_Rogers
    Naveen_Rogers , via OnePlus 8 , Sep 30, 2020 :
    I have 8 n 8 pro mobiles and I have updated both but in 8 AOD not working.. In settings ambient display AOD is disabled in 8 whereas 8 pro is working . Please fix the issue
  5. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Sep 30, 2020 :
    No. But they will if you return to stable either via rollback or upgrade to stable 11. When joining beta you need to stay on beta if a wipe is not acceptable.
    Always do backups. Or clean install but with media files stored locally on the computer or USB drives. Then it does not matter what happens and you don't loose anything.
    thenmozhi123 likes this.
  6. thenmozhi123
    thenmozhi123 , via OnePlus 8 , Sep 30, 2020 :
    One answer please whether to backup before upgrade
  7. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Sep 30, 2020 :
    If something goes wrong... Backup before. Copy the backup to external storage of some kind so you can put it back if needed.
    You can also do manual copies of pictures and videos and avoid full backups to avoid the possible issues that might come with backups.
    I have all pictures and videos stored online at all times. And I prefer to factory reset and clean install with no backups myself.
  8. A1601644271879
    Donut Oct 2, 2020
    B1600791948480 likes this.
  9. sapankumar1984
    Cupcake Oct 2, 2020
  10. Tonyatme
    Froyo Oct 3, 2020
    Tonyatme , Oct 3, 2020 :
    Some applications of Beta 2 cannot choose a full-screen display, so that large black borders will appear on the top station when used, especially in game applications.
    isabellevankleeck likes this.
  11. Cool_jaisss , via OnePlus 8 Glacial Green , Oct 3, 2020 :
    Yes same problem with me also in oneplus 8
    Arbaaz.in likes this.
  12. Muniyo
    Cupcake Oct 3, 2020
    Muniyo , via OnePlus 8 , Oct 3, 2020 :
    good but face problem in gry and black colour
    sum time I am watch movie so I face these problem .anybody faceing same problem ??
  13. kunal0187
    Cupcake Oct 3, 2020
  14. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Oct 3, 2020 :
    Usually this helps (see link below, try ALL Google recommended solutions). But rather often it does not seem to help in this case (if the users actually tried all steps).
    Some even did an factory reset and got it solved that way. I don't have this issue and I reset at Developer Preview 3. If this is triggered by something like 10 upgrade or something else I don't know.
    https://support.google.com/googleplay/answer/7513003?hl=en
    Alternative solutions is to manually update either via Apkmirror or the alternative store Aurora Store.
    https://auroraoss.com
    And of course report this via the feedback tool to Oneplus but possible also to Google if this might be a wider issue not limited to only Oneplus.
    I have had several different Play Store versions and not a single issue on any app ever since DP3.
  15. N1601889525689
    Cupcake Oct 5, 2020
  16. Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Oct 5, 2020 :
    What are you on and what region? If you are on 10 stable you don't get 11 until being relesed as stable version. That is rumored to be close to the 14th October since the 8T is launched then and will be the first Oneplus phone with stable 11 out of the box
  17. ce_franck
    Cupcake Oct 6, 2020
  18. ce_franck
    Cupcake Oct 6, 2020
