FAST CHARGE (DASH CHARGING) NOT APPEARING IN ONEPLUS 5T
  1. W1530888658700
    Cupcake Jun 20, 2019
    W1530888658700 , Jun 20, 2019 :
    I am using OnePlus 5T since one year. Nowadays the dash charge is not appearing in the device while charging and the device is charging slowly. After plugging the phone with the charger the notification light is turning red whereas earlier while dash charging was there the notification light turned blue. What's the solution of the problem....???
  2. Madnezz4Ever
    Ice Cream Sandwich Jun 20, 2019
    Madnezz4Ever , Jun 20, 2019 :
    Clean your charging port.
    Try another OnePlus cable.
    Apply some pressure and see if it even starts rapid charging.
    Your port might need to be replaced.
    Bouncer71 likes this.
  3. W1530888658700
    Cupcake Jun 21, 2019
  4. hashmune
    Froyo Jun 21, 2019
    hashmune , Jun 21, 2019 :
    If possible try another dash charger with your device to make sure your charger and cable working perfectly.
  5. sweggitity
    Honeycomb Jun 21, 2019
    sweggitity , Jun 21, 2019 :
    Clean the charger and the charging port.
    borft likes this.
  6. W1530888658700
    W1530888658700 , Jun 21, 2019 :
    Not working with another charger also.
  7. hashmune
    Froyo Jun 21, 2019
    Probably something wrong with the phone. have you tried restarting it? or resetting it?
  8. W1530888658700
    Yes... first thing I did restarted the phone but unable to sort out the problem
  9. hashmune
    Froyo Jun 21, 2019
    Try factory reset. if this is a temporary issue, it'll fix with a factory reset.
  10. W1530888658700
    Cupcake Jun 22, 2019
  11. hashmune
    Froyo Jun 22, 2019
  12. borft
    Jelly Bean Jun 22, 2019
    borft , Jun 22, 2019 :
    well, if no solution works, I guess you're sheer out of luck
    Nick 59 likes this.
  13. Nick 59
    Lollipop Jun 22, 2019
    Nick 59 , Jun 22, 2019 :
    Ok, you've tried a different cable and charger and you've cleaned out your charging port and tried all other possible fixes but issue still persists so you must have a hardware fault.
    Take or send your device to a Service Centre to be checked out.
  14. G_vivek_singh_RXCm
    G_vivek_singh_RXCm , Jun 22, 2019 :
    I had the same issue with OP5 along with audio port problem. For the 1st time I went to service center, they fixed my phone within 10 mins stating that it needed cleaning. Dash charge issue was fixed and problem didn't occurred for another 10 months or so. Again went to service center they changed both the ports (charging + 3.5mm audio jack). This time they said because of dust accumulation both the ports were worn out. Check for the "click" sound whenever you connect original USB with the port. If it is not there then do visit service center once. It costed me INR 1130 or USD 16. Hope that helps.
  15. F1561220704296
    Froyo Jun 22, 2019
    F1561220704296 , Jun 22, 2019 :
    Plug in the device to your computer, do you see the USB options in your notifications? If you turn on USB File Transfer, can you transfer files?
