Fast Charging is not working
  1. D1562346859529
    Cupcake Aug 12, 2020
    D1562346859529 , Aug 12, 2020 :
    the fast charger on my oneplus 6t is not working. now it charges at a normal rate. I am using the original charger and the brick which came with the box. please look into this problem.
  2. rhyd1am
    Jelly Bean Aug 12, 2020
    rhyd1am , via OnePlus 6T , Aug 12, 2020 :
    Try cleaning the charging port of the phone, both ends of the cable and the the charging brick.
    Ideally with a compressed air can, but a non conductive small object such as a wooden toothpick will also work.
    Sounds silly I know, but in all seriousness, 90% of the time issues such as yours, this solves it.
    D1562346859529, drl431 and Caomhin like this.
  3. D1562346859529
    Cupcake Aug 13, 2020
    D1562346859529 , Aug 13, 2020 :
    rhyd1am
    Sounds silly I know, but in all seriousness, 90% of the time issues such as yours, this solves it.​
    Hey,
    I tried it out, but still it is not working.
  4. Scherpenseel
    KitKat Aug 13, 2020
    Scherpenseel , Aug 13, 2020 :
    I doubt it is software related... So if cleaning the charging port and the cable isn't working, AND you have the cable pushed correctly into the wall mount it is either a deffective USB cable or a defective motherboard.
  5. D1562346859529
    ohhhk thank you. What should I do now?
