Fast charging issue for my OnePlus 7t via OnePlus 7T
  1. SNE_HITH
    Cupcake Sep 23, 2021
    SNE_HITH , via OnePlus 7T , Sep 23, 2021 :
    I am facing a issue regarding fast charging where it's been continuously connecting and disconnecting fast charging , I have even tried changing the charger even though I am facing the same issue and my phone is in extend warranty . Can I know what's the issue and how to sort it .
  2. Dresa91
    User of the Year 2016; Most Active User 2020 Sep 23, 2021
    Dresa91 , Sep 23, 2021 :
    can you please clean the usb port and check via settings - battery if optimizied charging is enabled. if yes, please disable it
    B1579881268696 likes this.
  3. SNE_HITH , via OnePlus 7T Glacier Blue , Sep 23, 2021 :
    Thank you for your information , I have cleaned the charging port and coming to optimised charging it stops charging not fluctuates between normal charging and fast charging and I even I turned it off though am facing the same issue
  4. Dresa91
    can you also clear cache in recovery?
    can you try another charger and/or cable?
  5. #5
  6. Dresa91
    also after cleaning the usb port, disabling optimized charging and clearing cache in recovery?
  7. #7
  8. Dresa91
  9. #9
  10. Dresa91
    And did you try another charger this time?
  11. #11
  12. Dresa91
    My question was after all the steps I suggested you
  13. #13
  14. Dresa91
    And what about the charger? Not only the cable
  15. #15
  16. Dresa91
    Okay, give it a try :)
    SNE_HITH likes this.
