5
FAST charging OBSERVED on OP2
  1. Dunnow Lollipop Jan 11, 2017
    Rogier123 likes this.
  2. rajatdixit Gingerbread Jan 11, 2017
    rajatdixit, Jan 11, 2017 :
    Please go to settings > backup and Reset > factory reset
  3. Praveen131 Cupcake Jan 11, 2017
  4. DutchDennis Donut Jan 11, 2017
  5. mikeyy233 Eclair Jan 11, 2017
    mikeyy233, Jan 11, 2017 :
    not really I'm getting 2000mah while charging
  6. nikhilanroid7 Gingerbread Jan 12, 2017
    nikhilanroid7, Jan 12, 2017 :
    Then there is no issue with cable..
  7. anweshani55 Eclair Jan 12, 2017
    anweshani55, Jan 12, 2017 :
    My device getting this type.can you tell me?
  8. G_Danish_Khan_fwuJ Cupcake Jan 12, 2017
    G_Danish_Khan_fwuJ, Jan 12, 2017 :
    though it is not affecting at all, unless switch off the device. but that's not the solution..
    I switched off the phone, and then charged, charging speed was awesome.... but that is too much hectic. also the battery is still draining so quickly
  9. nikhilanroid7 Gingerbread Jan 12, 2017
    Try to change cable.. Its so low.. It will take 4-5hrs to charge your phone
  10. anweshani55 Eclair Jan 12, 2017
    After changing cable seems like this..
  11. nikhilanroid7 Gingerbread Jan 12, 2017
  12. vikas seervi91 Cupcake Jan 12, 2017
  13. anweshani55 Eclair Jan 12, 2017
  14. aazeeshan256 Cupcake Jan 12, 2017
    aazeeshan256, Jan 12, 2017 :
    The issue is with the cable or adapter. So while charging Dial *#808# and open charger option. Check the Current.. It should be above -900mA
  15. shailendra5555 Eclair Jan 12, 2017
    shailendra5555, Jan 12, 2017 :
    i am getting 1625 mah for my OP2. Is it a issue ??
  16. boshk Froyo Jan 12, 2017
    boshk, Jan 12, 2017 :
    It's ok.
    Try to force stop some applications.
    shailendra5555 likes this.
  17. F_Teo_Dragoi_mRjo Eclair Jan 12, 2017
  18. Aashish.007 Ice Cream Sandwich Jan 12, 2017
    #38
  19. nikhilanroid7 Gingerbread Jan 12, 2017
    Compatibility issue with charger.. Change it with original or buy usb type c adapter from OnePlus
    #39
  20. nikhilanroid7 Gingerbread Jan 12, 2017
    Nope.. Its completely fine
    #40
