fast charging stopped working post oxygenOS 10.3.5
  1. Sarvesh.Mishra
    Cupcake Aug 8, 2020
    Sarvesh.Mishra , Aug 8, 2020 :
    Post OxygenOS 10.3.5 for the OnePlus 6 update fast charging stopped working.
    Is any way out for this issue?
  2. drl431
    Nougat Aug 8, 2020
    drl431 , Aug 8, 2020 :
    My OP6 does fast charge with the 10.3.5 update. But try cleaning out the usb-c connector on your phone. Use a toothpick or similar non-metallic probe. Look for pocket lint.
    Caomhin and rhyd1am like this.
  3. Sarvesh.Mishra
    Cupcake Aug 8, 2020
    I did cleaning of port in detail but issue is same. Charging was working absolutely fine just before update. i charged my device full before starting update. But now facing problem with charging. I'm not getting why this happened even my cellphone kept ideal for full day means didn't took any where today.
  4. rhyd1am
    Jelly Bean Aug 8, 2020
    rhyd1am , via OnePlus 6T , Aug 8, 2020 :
    Check that both ends of the cable are clean (and un damaged) too.
    Caomhin, drl431 and Sarvesh.Mishra like this.
  5. Sarvesh.Mishra
    Cupcake Aug 8, 2020
    ok thanks!!!
    rhyd1am likes this.
  6. B1576870052884
    Cupcake Aug 12, 2020
    B1576870052884 , Aug 12, 2020 :
    I'm facing the same issue on three devices 6 6T and 7
    Prior to the update I was getting the charging rapidly notification and it was charging quickly but not anymore.
    I've cleaned the ports and everything yet no fast charging, I infact used a warp charger too however no success.
  7. zayn_ys
    Honeycomb Aug 12, 2020
    zayn_ys , via OnePlus 6T Thunder Purple , Aug 12, 2020 :
    Clean the ports and check if the cable is connected to the adaptor properly.
    Try resetting your devices too. I guess it must been a long time since you had reset your phone.
    Give it a try.
