FCC ID For One Plus 8 Model In2013 via OnePlus 8
  1. JoselGarcia
    Cupcake Oct 30, 2020
    JoselGarcia , via OnePlus 8 , Oct 30, 2020 :
    Hello Comunity! I need your help with the matter enlisted below:
    I bought my OnePlus8 (model IN2013) through the OnePlus website, and I want to homologate the phone to use it in Colombia which is the country where I live.
    The Colombian Communications Commision is asking me to upload the FCC display grant or the FCC ID. I checked on the user manual and there's a section where it explains that the phone has this certificate, but I couldn't find the FCC ID.
    So I wanted to ask you if you know the FCC ID that belongs to this model (IN2013) or if you can help us find a way to fix this problem, I really like the brand and I would like to use my phone in my country. Or maybe if there's a letter or a file that can confirm that there's a product equality declaration and that this model is granted through another FCC ID.
    I really appreciate your help in this matter, thank you.
    Best regards,
    José Luis García
    Bogotá, Colombia
  2. Latrulli
    Latrulli , via OnePlus 8 , Oct 30, 2020 :
    Hello. I'm having the same problem you exposed.
    The colombian communications commission told me that the only one that can help with this FCCID is OnePlus directly. Because they're the ones who issue this documents with the FCC.
    Another way is that oneplus issue a equality declaration to the FCC that says that the IN2013 has the same characteristics as other models that has FCCID, as the IN2017 or IN2015.
    If anyone in oneplus is reading please help us to solve this problem, otherwise the phone is going to be blocked.
    Here I attached a equality declaration I found.
  3. e_liel
    Cupcake Nov 7, 2020
  4. Luis Jimenez S
    Cupcake Jan 10, 2021
    Latrulli and X1623776380655 like this.
  5. M1611936762737
    Cupcake Jan 29, 2021
  6. X1623776380655
    Cupcake Jun 24, 2021
    X1623776380655 , Jun 24, 2021 :
    Tengo el mismo problema con mi ONEPLUS 9PRO. Hago la marcacion *#07# y me dice que mi celular no tiene FCC ID.
  7. C1626534542978
    Cupcake Jul 20, 2021
    C1626534542978 , Jul 20, 2021 :
    pudiste homologarlo bro ?
  8. Latrulli
    Cupcake Nov 2, 2021
  9. Latrulli
    Cupcake Nov 2, 2021
