153
Feedback Tool - Let's improve OxygenOS together
  1. zxphenomenalxz Cupcake May 29, 2019
    zxphenomenalxz, May 29, 2019 :
    no sir. when you wake the phone up by tapping it shows the clock and typically one of the numbers is red. I was hoping for the option to choose the color instead of it being red, maybe if it matches up with the accent color you choose when theming.
  2. Aijaz ahmad Cupcake May 29, 2019
    Aijaz ahmad, May 29, 2019 :
    i have no colour options there Sir can u tell u in detail how will it work
  3. vamshi205 Eclair May 29, 2019
    vamshi205, May 29, 2019 :
    I have recently bought OnePlus 7pro and believe me guys your front camera is really worst. What's the point if spending 50k for a mobile and camera is not performing well? I m
    above pic is from one plus 7 pro
    below is from vivo 10k worth mobile
    tell me? Which one is really better? Even 10k worth mobile performing well. Completely depressed one plus not expected this from you.
  4. Aijaz ahmad Cupcake May 29, 2019
    yupp i was using vivo v 15 pro camera was awesome but still one ➕ is something better you only do not need camera nowadys
  5. vamshi205 Eclair May 29, 2019
    seriously? flagship doesn't mean it's performing good on some categories. a lot of difference in both images OnePlus should work more on AI based camera app..
  6. G_Rafael_Real_Cabrera_QD Cupcake May 30, 2019
    G_Rafael_Real_Cabrera_QD, May 30, 2019 :
    I use two SIM cards, one for private number and one for my work. In the weekends I do not want to activate one of the SIM cards. However I do not find a way to simply to skip the initial step of PIN introduction. I have to deactivate the second SIM slot by accessing the settings. Is it possible to skip the PIN introduction step for one of the slots? If not, could it be implemented? I had that option in my previous phone, and it was quite handy.
  7. royalisto Cupcake May 30, 2019
    royalisto, May 30, 2019 :
    What about adding a new feature for OnePlus phones without notification LED: using some display pixels to imitate LED (for example near the upper left corner of the screen). I think that would be useful, especially considering that there is no AOD support in OnePlus devices.
    Also I would like to see both energy saving and ultra saving modes like in Samsung, Xiaomi, Huawei or Apple devices (https://www.samsung.com/au/support/mobile-devices/power-saving-mode/ - here is some information about it).
  8. asmaan11 Cupcake May 30, 2019
    asmaan11, May 30, 2019 :
    hi recently upgraded to one plus 7 pro from one plus 5. the device is beautiful but I guess the battery drains pretty quickly. can the developers come up with an update to fix it. would be great .
  9. asmaan11 Cupcake May 30, 2019
    Have been using the one plus 7 pro for two days. the pop up camera is a great thing. But while videocalling on WhatsApp or Duo does anyone find it distracting or maybe will get the hang of it over time. It works seemlessly though.
  10. SamRange Cupcake May 30, 2019
    SamRange, May 30, 2019 :
    Gesture Controlls on OnePlus 7 Pro are not great. I would prefer to use gestures but they often stutter and are not very responsive. A swipe up to go to the task switcher may either not respond or go to the homescreen. I would love to see this get improved.
    Felix@OnePlus likes this.
  11. Shrutik ashiyani Cupcake May 31, 2019
  12. Arun0156 Cupcake May 31, 2019
    Arun0156, May 31, 2019 :
    os using much more ram approx 2.2GB so please improve ram management urgent fix this issue .......
  13. devesh darji Gingerbread May 31, 2019
    devesh darji, May 31, 2019 :
    The device which uses maximum RAM consider to be best in Android world. Why you want ram should be idle.
  14. Shrutik ashiyani Cupcake May 31, 2019
  15. abhishek25889 Cupcake May 31, 2019
    abhishek25889, May 31, 2019 :
    ambient display is not applied when double tap to wake up is enabled , and if ambient display is enabled there is no option to face unblock the phone..
    no portrait mode available with 48mp lens it's only available with telephoto which crops everything and makes it useless to click photos
    always on display is a must with AMOLED pannels like Samsung does it
    no 3.5mm to USB c cable in the box and nor is it available online at your store
    A1552619846944 likes this.
  16. Konstk Donut May 31, 2019
    Konstk, May 31, 2019 :
    a simple and logical one here - more control for notifications pulse light (screen edges light). Will be nice if we can set it to pulse for N hours if no acknowledgement
  17. T1558835804369 Cupcake May 31, 2019
    T1558835804369, May 31, 2019 :
    I used oneplus 7 pro and I face problem when I switch my mobile data from sim 1 to sim 2 at that time sim 1 goes in standby mode both sim are using 4G network.
    Please solve this isse as soon as possible.
  18. G_Nitesh_S_Wimt Cupcake May 31, 2019
  19. G_Nasrathulla_Shaikh_mxr Gingerbread May 31, 2019
  20. RockStarAKay Cupcake May 31, 2019
