153
Feedback Tool - Let's improve OxygenOS together
  1. Felix@OnePlus Donut Jun 2, 2019
    Felix@OnePlus, Jun 2, 2019 :
    I have the same problem, but only when I have the option "remove animations" enabled
    tohtamish likes this.
  2. tohtamish Cupcake Jun 2, 2019
    tohtamish, Jun 2, 2019 :
    I didnt have it enabled but did disable thrm via developer mode
  3. Felix@OnePlus Donut Jun 2, 2019
    doesn't make a difference in the result in my experience. At least, if you disable all 3 options for animation speed there. I'm testing, if the bug still occurrs when only one or two are set to no animation
  4. tohtamish Cupcake Jun 2, 2019
    I've put them. All. On 0.5 animation, hope to avoid the issue
    Noticed this happens also somwtimes. With the keyboard (i use swift key)
  5. Felix@OnePlus Donut Jun 2, 2019
    in my brief testing setting the window animation scale to "animation off" causes the Problem. Setting it to 0,5 and the other 2 to off helped in my case
    MR.BEN312 and tohtamish like this.
  6. dallasnights Donut Jun 2, 2019
  7. MR.BEN312 Honeycomb Jun 2, 2019
  8. Shivaprasadc9 Cupcake Jun 3, 2019
    Shivaprasadc9, Jun 3, 2019 :
    hi am using one plus 6t 6gb ram and 128 gb storage.
    off late am experiencing the lot lags and delays and camera app crashing. it just feels like everything kinda got slowed down. installed cleaner apps to clear ram but still no Improvement. could you please help me out. app closing app opening is all getting struck.
  9. devesh darji Gingerbread Jun 3, 2019
    devesh darji, Jun 3, 2019 :
    is it after recent beta update?
  10. S1559415771022 Donut Jun 3, 2019
    S1559415771022, Jun 3, 2019 :
    Camera-Shutter Button OP7 Pro: Please provide a floating shutter button.
    It would b of great help in taking selfies on this big screen. I'm always in fear of losing grip of the phone when stretching my finger to tap the shutter button at the bottom of the screen.
  11. M1536219779817 Donut Jun 3, 2019
    M1536219779817, Jun 3, 2019 :
  12. Shivaprasadc9 Cupcake Jun 3, 2019
    No. I haven't done any updates. it's just no more about experience.
  13. Shivaprasadc9 Cupcake Jun 3, 2019
    3 days back I was using nightscape mode on while taking pictures. the camera app was just reading and even it didn't take any photos
  14. ank17 Cupcake Jun 3, 2019
    ank17, Jun 3, 2019 :
    my 1 year old one plus 5t something lags .the notification shade ,the launcher ,app lags but however a quick Reboot fixes the problem Temperley . please fix this in a future update.love one plus
  15. A1559150789572 Cupcake Jun 3, 2019
    A1559150789572, Jun 3, 2019 :
    Hello. With this new update, sometimes, when i unlock my oneplus7 pro, my phone freezes, like theres no status bar and i cant move around. Can you please fix it? It starts to get annoying that i have to reopen my phone. Thanks
    ank17 likes this.
  16. Suriyalucky Cupcake Jun 4, 2019
  17. thanospc Cupcake Jun 4, 2019
    thanospc, Jun 4, 2019 :
    please also do: Optimized Double Tap to Wake and Ambient Display on OnePlus 6T. Sometimes you double tap and never wake. You have to wake 5min or 10 and then double tap again to wake. Also double tap to wake not work if someone calls you and the screen is black when you speak during the call.
  18. S1541091449963 Cupcake Jun 4, 2019
    S1541091449963, Jun 4, 2019 :
    On my OP7P in the messaging app when group texting the sender's name does not appear. There's no way to know who is sent the message.
  19. G_Aravind_Mano_EwNn Cupcake Jun 4, 2019
    G_Aravind_Mano_EwNn, Jun 4, 2019 :
    My rear camera in OnePlus 3, ask to restart your camera and after restarting my phone rear camera again not working.
    As OnePlus user, If there is any update on software side kindly find it out and fix it.
  20. I1541746839970 Cupcake Jun 5, 2019
    I1541746839970, Jun 5, 2019 :
    The notification bar doesn't come down easily while calling.
    Battery drain while idle is quite more, I had a battery drain of 8% overnight on standby.
