153
Feedback Tool - Let's improve OxygenOS together
  1. C1559710625042 Cupcake Jun 5, 2019
    C1559710625042, Jun 5, 2019 :
    What is the latest Oxygen OS for the One Plus 7 pro? my system indicates 9.5.6, however One Plus website indicates 9.5.4.
  2. devesh darji Gingerbread Jun 5, 2019
    devesh darji, Jun 5, 2019 :
    They put it few days after release
  3. devesh darji Gingerbread Jun 5, 2019
    Have you updated one plus launcher app..They solved it
  4. I1541746839970 Cupcake Jun 5, 2019
    I1541746839970, Jun 5, 2019 :
    They fixed the bar issue batteey left.
  5. I1541746839970 Cupcake Jun 5, 2019
  6. E1558101722578 Cupcake Jun 5, 2019
  7. H1558102186529 Cupcake Jun 5, 2019
    H1558102186529, Jun 5, 2019 :
    The color saturation from the camera is too high, I have to edit every photo back to normal levels
  8. ramohan87 Cupcake Jun 6, 2019
  9. F1534005764851 Cupcake Jun 6, 2019
  10. Rijuld Cupcake Jun 6, 2019
    Rijuld, Jun 6, 2019 :
    Device: One Plus 7 (6+128)
    Suggestion/bug - The night mode takes time to become active everytime I unlock my device. the screen slowly turns warm in colour, and the transition is clearly observable and irritating. especially when using in a dark room, using Whatsapp also becomes a nuisance.
  11. I1558436067746 Eclair Jun 6, 2019
    I1558436067746, Jun 6, 2019 :
    Update 9.5.5 EU
    1. Facebook videos are not loading and playing automatically ( have to clean user data of the FB app )
    2. Tap once to AWAKE, EVEN ONE TAP is not always working, displays is just freezes and not responding for a single tap. ( You can keep tapping non stop as many times as you want and nothing happening )
    3. Sometimes when you use app for typing messages keyboard appears blank and black, looks like ( not loaded) have to close a chat and open again. Typically happening on messenger app
    4. Not always showing pop ups or animations. Sometimes absolutely opposite happening, you may be in the chat and actively typing/chatting with a person, and for some reason when same person is answering you receiving notification and pop ups from same person ( even if you are in the chat, feels like phone thinks that you are away and didn't see messages ). Delayed notifications or something like that. Messenger app
    5. Fingerprint unlock sensor is not responding correctly. Scanning finger print to unlock phone but it do not recognise it and have to open phone manually with the code only. After a while or after restart it goes away, and comes back again. Something wrong with scanning sensor
    6. Dropdown menu from the top of the screen is not always showing up, when you swipe with your finger down. ( even if its enabled in options to swipe anywhere on the screen ) . Sometimes you must to put your finger on the very top of the screen and swipe then.
    7. If you go to Accessibility > Turn off animations, Screen always flickering and blinking when you using phone. Must turn ON animations back if you wanna get rid of flickering
    8. During ON CALL speaker screen is always locked and its not reacting to fingerprint, can open it only with a button on the side and manually entering code
    Mariarichard likes this.
  12. Darius_Apanskas Cupcake Jun 6, 2019
    Darius_Apanskas, Jun 6, 2019 :
    App drawer need column count property, I use large fonts and can't see apps names only several letters :( . Shelf need bit large fonts too or possibility to change them. This problems forced me to use Nova instead native launcher.
  13. H1550783324081 Cupcake Jun 7, 2019
  14. X1559579212175 Cupcake Jun 7, 2019
    X1559579212175, Jun 7, 2019 :
    please include the wide angle lens in taking videos on OnePlus 7 pro....it would improve the overall camera experience in the video aspect of the one plus 7 pro...
  15. BloodWolfOP Cupcake Jun 7, 2019
    BloodWolfOP, Jun 7, 2019 :
    latest update of OnePlus 7 Pro has a notification panel opening issue
    whenever i am in a game or watching a youtube video horizontally the panel takes 2to 3 slides to open
    vighnesh js and MR.BEN312 like this.
  16. S1558110415108 Cupcake Jun 7, 2019
  17. Mariarichard Cupcake Jun 7, 2019
  18. keygenx Cupcake Jun 7, 2019
    keygenx, Jun 7, 2019 :
    The ram management is terrible.
    Using OOS 9.0.14 on OP 6T. All battery optimizations turned off.
    When switching between apps, they reload unpredictably. Sometimes it reloads and sometimes it'll be where I left off.
    Example:
    I might have typed up a long paragraph in chrome, then after I read a PDF and come back the page would have reloaded and everything I typed would've gone. Similar behavior occurs even when switching tabs. It happens even if I lock chrome.
  19. davidbadajoz Cupcake Jun 7, 2019
    davidbadajoz, Jun 7, 2019 :
    7 Pro here.
    The lowest volume is too high. Can I have lower volume than mid-loud? This is a real question.
  20. davidbadajoz Cupcake Jun 7, 2019
    MR.BEN312 likes this.
