213
Feedback Tool - Let's improve OxygenOS together
  1. D1579417379169
    Cupcake Jan 20, 2020
    D1579417379169 , via OnePlus 6 , Jan 20, 2020 :
    after the update of 10.0.3 my emojis are not showing gboard and also not showing in any screen instead of it cross are showing so look after the problem
    please look after the problem .
  2. Z1541095711164
    Cupcake Jan 22, 2020
    G_Kirk_Fontaine_MBlG likes this.
  3. G_Kirk_Fontaine_MBlG , via OnePlus 7 Pro T-Mobile , Jan 23, 2020 :
    I am having issues with my media all media( you tube , music apps ,etc) stopping inconsistently frustrating bur not a deal breaker
    one plus 7 pro Android 10
  4. Y1577375938804
    Cupcake Jan 23, 2020
  5. H1578034362720
  6. Yashwanth pinnenti
    Eclair Jan 23, 2020
  7. Libin Raveendran
    Cupcake Jan 25, 2020
    Libin Raveendran , Jan 25, 2020 :
    Kindly request to bring out GaN components to chargers. Initially it may be tough but later it saves a lot of time and effort as well as improves energy enormously.
    Please bring a 30000 mAh power bank with warp charge 30T support.
    Please bring fast wireless charging equivalent to warp charge or else it's not worth bring up to OnePlus' device known for its ultra fast charging
  8. DeepRanjan
    Cupcake Jan 28, 2020
    DeepRanjan , Jan 28, 2020 :
    kindly remove the power off nd restart device wen phone is locked.as i don't feel safe..if phone misplaces anyone can switch off device.. kindly have a look in this.thanking u
  9. Vissu2020
    Cupcake Jan 30, 2020
  10. T1560067017686
    T1560067017686 , Jan 30, 2020 :
    I have issue with my keyboard. Whenever I try to write something nothing appears. And this is happening quite often.
  11. O1580399170564
    Cupcake Jan 31, 2020
    O1580399170564 , Jan 31, 2020 :
    I can't able to send Feedback Suggestions, it's showing 'Posting' but after a long time also it's not getting posted and I tried by rebooting my device, then also it's showing same. Pls resolve it.
  12. thakuranuj.mitthu
    Cupcake Feb 3, 2020
    Harpreetskakkar297 likes this.
  13. Q1552258195532
    Cupcake Feb 3, 2020
    Binoy Mathew likes this.
  14. Julio_Piedra
    Cupcake Feb 5, 2020
    Julio_Piedra , via OnePlus 7 Pro , Feb 5, 2020 :
    My One Plus 7 Pro have a important bug with the original One Plus audio to USB-C converter. Several days ago, it stopped working with the same earphones I used every day. The earphones work well, but when they are connected through the converter to the USB-C port, I could listen to the other person, but the other couldn't listen to me. I have also tried with audio to USB-C converter designed by a different brand, and I have the same issue. The earphones work perfectly with other devices. Does it have to do with the software of the mobile phone? The USB-C port doesn't seem to be damaged.
    Please let me know what can I do, I use the phone for work and cannot use it without earphones. Thanks a lot!
  15. hiteshdahiya
    Cupcake Feb 10, 2020
    hiteshdahiya , Feb 10, 2020 :
    my phone shows same data in both WhatsApp application and parallel WhatsApp application with same data and messages after the update. anyone have same problem?
  16. V1541676212518
  17. Harpreetskakkar297 , via OnePlus 7 Mirror Red , Feb 11, 2020 :
    Hi buddy....
    Try to
    1. Clear Cache for both apps
    2. Force Stop both Apps
    3. Kill from Recent Apps
    4. Restart your Device
    Then Check it again... It'll be helpful...If in Case its not then you have to take Necessary Backups and try To Uninstall and Install again the App.
    Enjoy your life
    Regards
    Happy User of One Plus
  18. Binoy Mathew
    Eclair Feb 12, 2020
    Binoy Mathew , Feb 12, 2020 :
    I have the exact same problem. Only during Battle Royale matches. The screen goes blank/black, even though the match is ongoing. At times, it completely crashes. I have reported it to the game developers as well. But I don't see complaints from other players.
    OnePlus developers are too busy with current flagships. They have forgotten about their older customers and older devices. I'm starting to regret getting a OnePlus device.
  19. H1534517070548
    Froyo Feb 17, 2020
    H1534517070548 , via OnePlus 6 , Feb 17, 2020 :
    after updating to oxygen OS 10.3.1 on my one plus 6 .. mobile start hanging..and automatically switch off and on
    .. it is so embarass to use... gallery will be automatically hang.. plz fix soon or tel me how to go back older version of OS
